Supercharged B16b ?
Old Mar 20, 2004 | 09:35 AM
  #51
norcalcrx's Avatar
Default Re: (hypa)
If you decided to go sc i would deffinately look into a procharger setup. That way you have an ic to drop those charge temps.
Old Mar 20, 2004 | 09:39 AM
  #52
norcalcrx's Avatar
Default Re: (norcalcrx)
If money was no object K20r all the way.
http://hondata.com/racecar/
Look at the power with just bolt ons.
Old Mar 22, 2004 | 06:26 AM
  #53
Jon V's Avatar
thats definetly something to think about
Old Mar 23, 2004 | 05:56 PM
  #54
Cookie's Avatar
Default Re: (Jon V)
An acquaintance of mine has a RSX-S with the Race Spec JRSC running 5lbs boost, using 440cc injectors and a JR Tuned/Hondata flashed ECU.
K20a Didgets:
Type Inline-4; Aluminum head and block
Valvetrain DOHC 4-valve/cyl.; i-VTEC
Displacement [cc] 1998
Bore & Stroke [mm] 86.0 x 86.0
Compression Ratio 11.0:1
Redline [rpm] 7900
Max. Power [Bhp at rpm] 200 at 7400
Max. Torque [lb-ft (Nm) at rpm] 142 (192) at 6000
Bhp/Liter 100.1
No intercooler! He's showing 268 fwhp on paper.
THIS is the way to go!
Modified by Cookie at 9:58 PM 3/23/2004
Old Mar 23, 2004 | 08:55 PM
  #55
Cookie's Avatar
Default Re: (Cookie)
Power to weight ratio for a typical EG -- 2320 x 285 whp = 8.14
Power to weight ratio for a typical RSX-S 2767 x same 285 = 9.71
Apples to apples, the lighter car/same horsepower wins.
Old Mar 23, 2004 | 10:33 PM
  #56
keebler65's Avatar
nice
although how could you give up the looks of the RSX?
Old Mar 24, 2004 | 05:53 AM
  #57
Jon V's Avatar
Default Re: (keebler65)
I gotta an EK but K20a turbo sounds nice
Is that K20a or A2?
Type R
Old Mar 24, 2004 | 10:33 AM
  #58
Cookie's Avatar
Default Re: (Jon V)
Jon, K20a2 is the Civic Si's engine. K20a is the RSX-S
Old Mar 24, 2004 | 11:53 AM
  #59
Jon V's Avatar
what is the RSX (integra) type R code
K20A4?
Old Mar 24, 2004 | 01:19 PM
  #60
Cookie's Avatar
Default Re: (Jon V)
If this doesn't make you salivate, you are on some sort of dry mouth drug!
Old Mar 24, 2004 | 01:21 PM
  #61
Cookie's Avatar
My only Q is why he didn't go straight out to the front to get forced air to the intake? 90 degree angle or not.
Old Mar 24, 2004 | 01:29 PM
  #62
Jon V's Avatar
looks like he removed the headlight, and it probly only cost him $20 to make that intake. Not bad for a $5000+ swap. I would just fab some ITB's and get a stand alone ECU
Old Mar 24, 2004 | 01:31 PM
  #63
Jon V's Avatar
whats the biggest issue with a swap like this axles?
Old Mar 24, 2004 | 02:58 PM
  #64
nigel's Avatar
I dont know about the mcDondalds colors, but thats a clean *** swap.
Old Mar 24, 2004 | 04:11 PM
  #65
Cookie's Avatar
Default Re: (nigel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I dont know about the mcDondalds colors</TD></TR></TABLE>
Not everyone wants to live in a 'Vanilla' world.
As far as the being the premier authority on K20a swaps, I am not. But I am a fast study.
K20 to (typical) EG swap.
You will need;
Mount kit
Header 4-1 equal length
pnp harness 350
SS fuel lines Guage incl
clutch lines
Str fuel rail
axels with cores *Rsx Cores or Gsr
Consider too, that you will have to 'rethink' the length of your b-pipe to meet the down-pipe of the header. Along with other things not listed.
One of K20EG's installs
Old Mar 25, 2004 | 05:57 AM
  #66
Jon V's Avatar
damn thats my **** !!!
well not really but it should be
Can you get some more pics of this guys set up?
Old Mar 25, 2004 | 02:20 PM
  #67
EtaK's Avatar
Default Re: (Jon V)
good choice...wish i had da mula
Old Mar 25, 2004 | 03:50 PM
  #68
Cookie's Avatar
Default Re: (Sepulcher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> mula </TD></TR></TABLE>
Plan to spend, not only the price of you car, but about 7500.00 (+/-) on the engine swapage, (mounts, trans, axles, reconfiguring all linkage, et.al., etc.), ECU management systems and bits to have it flow with no failures.
Wait a few years for prices to come down and for the NEW to calm down.
The biggest obstacle will be the lack of off-the-shelf, high-performance parts. Anybody wishing to build up the internals of their K engine will simply have to wait for those parts to fill the pipeline.
Unless you have endless amounts of cash, the best bang for the buck still belongs to the B series engines.
Modified by Cookie at 5:45 PM 3/25/2004
Old Mar 25, 2004 | 06:18 PM
  #69
Jon V's Avatar
Ya but
Old Mar 25, 2004 | 08:34 PM
  #70
Cookie's Avatar
Default Re: (Jon V)
Okay you droolin' foo! BUY THIS WRECK AND GET IT ON!!
Description : 2003 ACURA RSX TYPE-S
Color : BLACK
VIN : JH4DC*****C
Mileage 7,965
A Mint engine and standard transmission, want to sell it as a complete drop out with harness and ECU. $7500.00
Comes with a 90 day guarantee.
Stock # 031571
IMPORTANT READ;
The K series engines spin clockwise, like most other engines, and as a result they sit on the right side of the engine bay. In order to make one basic engine bay that would fit both a left-side and a right-side engine, Honda had to do a little bit of clever engineering. The transmission side of the engine in each car attaches directly to the frame using a beefy engine mount, which bolts to the tranny case. The pulley-side mount bolts to a "box" that is welded to the frame. The problem is that the "box" is on the right side of the engine bay in the RSX, Type-S, Si and CR-V, and on the left side in the EM Civics. Dimensionally, there isn't much of a problem. The K engines should fit into the Civic engine bay just fine without any clearance issues. Getting it to bolt in place, however, will require some tricky mounts. To top it all off, you'll have to drop in the K20 transmission and driveshafts as well.
Knightz
58
Feb 1, 2011 05:17 PM
RDix
12
Mar 27, 2006 02:31 PM
4drBlankito2.0
Mar 7, 2005 01:57 PM
mrtrex
10
Jul 27, 2004 08:06 PM
CW_97_ITR
Aug 1, 2002 08:44 AM
