Stumped
Old Aug 31, 2009 | 05:20 PM
schock3's Avatar
Default Stumped
Ok. I have a 1990 crx Si w/b16a have been installing a rev hard turbo kit and it is finally competed and sitting. I have bought 450cc injectors and a p28 basemapped for turbo and converted to obd1 with a rywire harness. I have also purchased a TD-44U Dizzy. when i got done the car started. when i went to pull it out of my garage it would bog...i didnt even make it 5 feet out of the garage and it died. NO CEL'S! checked everything but to see if i was getting spark because i have no idea how to check with just one person. I feel that the problem is in the dizzy because after i installed the 450cc injectors when i was still obd0 everything was perfect running like a champ. so.. the wires i have for the dizzy on the engine side are ( yel/grn, blue, blue/yel, Tan, Wht, Wht/blue, Tan/Blue) Ive been searching (on here and on google) and found a few things like https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/obd0-obd1-distributor-wiring-1349052/
did what it said and the car would just crank and crank. I found something else and got it to start and thats when the problems started. someone PLEASE help me out. thanks guys
Old Aug 31, 2009 | 06:16 PM
Bailhatch's Avatar
Default Re: Stumped
you need fuel, spark and compression to make it run. Check those first instead of guessing.
Old Sep 1, 2009 | 12:57 PM
schock3's Avatar
Default Re: Stumped
got fuel and compression checked and re checked wiring its gotta be the dizzy...how do i check with just one person?
schock3
12
Sep 5, 2009 01:00 PM
enjoi_hendrix
Jul 16, 2009 06:02 PM
95f22a1
22
Feb 2, 2009 10:12 AM
DOHCarp
Sep 19, 2006 05:24 PM
jdmd15bhatch
Sep 26, 2005 05:55 PM
