Stroker turbo..?
Old Aug 24, 2005 | 11:30 PM
Ls-Turbo's Avatar
Default Stroker turbo..?
ive been recently reading up on a stroker kit because my crank is shot.. but i havent seen to many people doing it with a turbo with the stroker kit.. ne advantages or disadvantages..?
Old Aug 25, 2005 | 12:52 PM
Ls-Turbo's Avatar
Default Re: Stroker turbo..? (j.d.m.ness)
bump
Old Aug 25, 2005 | 12:56 PM
CoreyR's Avatar
faster turbo spool from increased displacement (obviously) and more torque from the longer stroke.
disadvantage is the longer stroke makes it less safe to rev the motor high because of piston speeds. or thats how i understand it anyways.
Old Aug 25, 2005 | 01:06 PM
.dave's Avatar
i HAS questions ?
Default Re: Stroker turbo..? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">faster turbo spool from increased displacement (obviously) and more torque from the longer stroke.
disadvantage is the longer stroke makes it less safe to rev the motor high because of piston speeds. or thats how i understand it anyways.</TD></TR></TABLE>
Yeah, that pretty much covers it. I think another reason is because of the cost as well. I'm not sure the torque advantage down low would be truly beneficial because most people have enough trouble hooking up on the street as it is.
But I say go for it. I haven't seen a stroked turbo setup posted on here before, so I think it'd be something cool. Just make sure its a B18 and not a B16.
Who knows, maybe you'll start the next bandwagon.
TeamYelloHead's Avatar
if u use a stroker kit, u gotta use oversize pistons which results in high comp, high comp = faster reving= faster spooling but causes ur motor to be unstable like a ****. thats why no one really boost itr motors and stuff and if they do they run low comp pistons
Old Aug 25, 2005 | 01:16 PM
rhd's Avatar
rhd
Default Re: (TeamYelloHead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamYelloHead &raquo;</TD></TR><TR><TD CLASS="quote">if u use a stroker kit, u gotta use oversize pistons which results in high comp, high comp = faster reving= faster spooling but causes ur motor to be unstable like a ****. thats why no one really boost itr motors and stuff and if they do they run low comp pistons</TD></TR></TABLE>
why do you HAVE gto used oversized pistons? you can stroke a stock bore, no?
and PLENTY of ppl boost ITR motors, they aren't that much higher than GSR's and the same basically as B16's
Old Aug 25, 2005 | 01:24 PM
Default Re: (rhd)
my bad i did some readin, i guess u can stroke a stock bore, but i think 10.6.1 comp on a usdm itr is pretty high for turbo, jdm spec itr is like 11.0.1. correct me if im wrong but gsr comp, isnt it like 9 or so.
Old Aug 25, 2005 | 01:41 PM
earl's Avatar
You will already make more power than you can use just by adding the turbo. Stroker kits are more efficient on all motor applications.
Old Aug 25, 2005 | 04:16 PM
boosted92's Avatar
Default Re: Stroker turbo..? (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">You will already make more power than you can use just by adding the turbo. Stroker kits are more efficient on all motor applications.</TD></TR></TABLE>
Not to mention the potential oil control issues, as witnessed by the tech43 B16 stroker setups.
Old Aug 25, 2005 | 07:49 PM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamYelloHead &raquo;</TD></TR><TR><TD CLASS="quote">my bad i did some readin, i guess u can stroke a stock bore, but i think 10.6.1 comp on a usdm itr is pretty high for turbo, jdm spec itr is like 11.0.1. correct me if im wrong but gsr comp, isnt it like 9 or so.</TD></TR></TABLE>
USDM GSR is 10.0:1
JDM is 10.2:1
USDM b16 is 10.2:1
JDM b16 is 10.4:1
i THINK that's correct
Old Aug 25, 2005 | 08:12 PM
CoreyR's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">
USDM GSR is 10.0:1
JDM is 10.2:1
USDM b16 is 10.2:1
JDM b16 is 10.4:1
i THINK that's correct</TD></TR></TABLE>
JDM GSR is 10.6
Old Aug 25, 2005 | 08:17 PM
rhd's Avatar
rhd
thanks...figured i'd get at least one wrong, haha
Old Aug 26, 2005 | 09:06 AM
boost_addict's Avatar
whats wrong with the tech43 b16 stroker kits if u don't mind me askin
Old Aug 26, 2005 | 01:24 PM
boosted92's Avatar
Default Re: (boost_addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost_addict &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with the tech43 b16 stroker kits if u don't mind me askin</TD></TR></TABLE>
If you read up on them, you would find that the only ones on this board that were running were having oil control issues. The B16 deck height is just too damn short for an LS crank and LS rods, so the piston pin completely intersects the oil ring, which gives it much less support than if there were piston skirt behind it. This leads to lower tension on the oil ring, and more blowby/oil useage. I don't recall off the top of my head how bad it was, but it seemed pretty excessive on one of the motors.
Old Aug 26, 2005 | 01:39 PM
captainh22's Avatar
Default Re: (boosted92)
this is my set up wouldnt know the negatives of doing it yet because Im still waiting on a head gasket
wolfman93
Nov 16, 2015 06:10 PM
CR-V-tech
Aug 1, 2006 08:58 PM
chex329
Oct 24, 2005 01:28 PM
Eresuncabron
Aug 16, 2004 06:44 PM
Lsos
Dec 24, 2002 06:30 AM
