STR or Golden Eagle intake manifod? Which one?
I was wondering if either is better than the other, I know some of you are going to say GE because they have such a good rep., but I personally like the STR and I believe they flow around the same CFM's. Any dyno's on either one, which one would you pick? They both are around the same price with the same design, recommendations? thanks
Golden Eagle Mfg. was the original designer and producer for the STR manifold. They still are producing the manifolds and they are on some of the fastest street and race cars in the world. The Prelude manifold should be in stock and ready to ship.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">I was wondering if either is better than the other, I know some of you are going to say GE because they have such a good rep., but I personally like the STR and I believe they flow around the same CFM's. Any dyno's on either one, which one would you pick? They both are around the same price with the same design, recommendations? thanks</TD></TR></TABLE>
what about b16 mani?
Ya I remember that...I think golden eagle made a lot of stuff for str and str just put there name on it... But yes that manifold does make a LOT of power.. I know I need one and My buddy has been running one since they cane out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">GE
GE manifolds are sweet looking
</TD></TR></TABLE>GE manifolds are sweet looking
I don't get why GE and STR or Venom sell there Manifolds for 2 times as much as a Edelbrock X.I mean correct me if I am worng but there all kinda the same thing.i have ran a Edlebrock for years and have had great numbers and also save about 360 bucks to put somewhere else. just my 2 cents.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">i look at it this way u can fit mor air in a 4" square then u can in a 4" circle
Well put.
Which design does the air move the quickest?
</TD></TR></TABLE>Well put.
I started a thread on the topic of what manifold is best for boost a while ago..I think the manifolds fit into basic categories, and the performance goes from the type r /aebs/skunk2 to victor x/bbk to ge/venom/str to full race/endyn..but i could be wrong about the victor/bbk vs the ge/etc..I never found any good dyno tests. People also said there are significant differences between the various box shaped plenum manifolds..
I guess I would recommend the victor x or the bbk though..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">i look at it this way u can fit mor air in a 4" square then u can in a 4" circle </TD></TR></TABLE>
Actually The circle would flow more then the Square... I think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSR-Abuser »</TD></TR><TR><TD CLASS="quote">
Lets say for example that the same amount of air is goign through the intake, the square will have slower air velocity which you may not want unless you are pushing a whole lot of air in which case the circle becomes a restriction because of smaller cross-sectional volume. the opposite happens when flowing the same with the circle it would have a higher velocity over the square and at a certain point the velocities would be the same but the square would surpass it in flow.
I bet that was the most confusing thing ever but yea figure it out lol
</TD></TR></TABLE>Lets say for example that the same amount of air is goign through the intake, the square will have slower air velocity which you may not want unless you are pushing a whole lot of air in which case the circle becomes a restriction because of smaller cross-sectional volume. the opposite happens when flowing the same with the circle it would have a higher velocity over the square and at a certain point the velocities would be the same but the square would surpass it in flow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
Is it wrong of me to have actually made since of that? It sounds right to me.
</TD></TR></TABLE>Is it wrong of me to have actually made since of that? It sounds right to me.
i have a victor x. and i believe most people run the jg/victor x manifolds
if u look on this thread. https://honda-tech.com/zerothread?id=1536734&page=1
someone wrote this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gsrteg »</TD></TR><TR><TD CLASS="quote">ok when they say non turbo, they usually mean it, as an engineer major i can tell u that most manifolds which are designed specifically for boost have more of a spherical shape to them rather than a box, this is becuase when air is compressed inside of it, the object wants to expand outwards into a round shape becuase this will allow it to have the greatest volume and be able to hold compressed air nicely, this is also the reason why aircrafts which used compressed cabins are also shaped the same way, becuase any shape object with pressure inside of it wants to expand into the round shape and have the most amount of volume. so chances are this manifold being made out of aluminum, with a little bit of heat and some nice boost inside of it, its sure to blow the chinese welds right off of it as another member beautifully stated.</TD></TR></TABLE>
someone wrote this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tornadom »</TD></TR><TR><TD CLASS="quote">
Well put.
Which design does the air move the quickest?</TD></TR></TABLE>
at 30psi i dont think it matters
joking aside if you are n/a im sure the way it moves around in the intake makes a difference but when you FORCEFEED it i cant see that much of a diference i would be more concerned about how much air i could cram in it
Well put.
PrecisionH23a
Sep 15, 2004 11:21 PM
