Stock map sensor is good for 14 psi?
Old Jul 5, 2007 | 09:21 AM
DrivinVtec's Avatar
Default Stock map sensor is good for 14 psi?
Isnt a stock map sensor something like 1.5 bar? I can rememeber. Also looking for a 3bar map sensor with pig tial.
Old Jul 5, 2007 | 09:25 AM
HiProfile's Avatar
Default Re: Stock map sensor is good for 14 psi? (DrivinVtec)
1.75bar, meaning 11.2ish psi
Old Jul 5, 2007 | 09:29 AM
DrivinVtec's Avatar
thanks
Old Jul 5, 2007 | 09:31 AM
MidwestAutoWorks's Avatar
Default Re: Stock map sensor is good for 14 psi? (HiProfile)
i bar is almost 14 psi, so i doubt that 1.75 will work, but I have heard up to 11
Old Jul 5, 2007 | 09:33 AM
DrivinVtec's Avatar
Default Re: Stock map sensor is good for 14 psi? (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">i bar is almost 14 psi, so i doubt that 1.75 will work, but I have heard up to 11</TD></TR></TABLE>if a bar is close 14psi an are stock one is 1.75..why wouldnt hold 14psi?
Old Jul 5, 2007 | 09:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">1.75bar, meaning 11.2ish psi</TD></TR></TABLE>
read this
he is saying 1.75 bar is 11.2 psi
Old Jul 5, 2007 | 09:48 AM
boostedcivicsir's Avatar
Mr. Badwrench
1.75 bar =
atmosphere (so take 1 bar away) + .75 bar (11.02) = 1.75 bar
you have to take atmospheric away.
Old Jul 5, 2007 | 09:50 AM
Bailhatch's Avatar
Default Re: Stock map sensor is good for 14 psi? (boostedcivicsir)
1 bar is 14.5psi if anyone cares
Old Jul 5, 2007 | 09:53 AM
Mr. Badwrench
Default Re: Stock map sensor is good for 14 psi? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">1 bar is 14.5psi if anyone cares </TD></TR></TABLE>
so there would be the .2 i am missing.
Old Jul 5, 2007 | 10:06 AM
mtber's Avatar
Get your self a 2.5bar motorolla or a 3bar gm sensor
Old Jul 5, 2007 | 11:18 AM
spets's Avatar
1 bar is 14.7, not 14.5
Old Jul 5, 2007 | 11:30 AM
Mr. Badwrench
Default Re: (spets)
google 1 bar =
14.504 psi
1 atmoshpere at sea level is 14.7
i know i was confused at first too.
Old Jul 5, 2007 | 06:48 PM
DrivinVtec's Avatar
Default Re: (boostedcivicsir)
hahaha..omg. stock map sensor is good for what psi?
Old Jul 5, 2007 | 06:58 PM
Bailhatch's Avatar
Default Re: (spets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spets &raquo;</TD></TR><TR><TD CLASS="quote">1 bar is 14.7, not 14.5</TD></TR></TABLE>
no, that is not true. one ATM is 14.7
Old Jul 5, 2007 | 06:59 PM
SovXietday's Avatar
Default Re: (DrivinVtec)
11.2 PSI
Old Jul 5, 2007 | 07:05 PM
Bailhatch's Avatar
Default Re: (SovXietday)
you sure it's not 10.875psi?
Old Jul 5, 2007 | 07:07 PM
Bailhatch's Avatar
Default Re: (Mr Wonderfull)
how are you guys even getting 11.2?
.75 x 14.5 = 10.875
Old Jul 5, 2007 | 07:14 PM
DrivinVtec's Avatar
haha..man. didnt think it was that hard. so stock map it good for 11.2psi, or 12psi or 14.5psi lol
Old Jul 5, 2007 | 07:17 PM
93turbo16's Avatar
If you plan on going over 11 then get a bigger map sensor.
It is only good to around 11 psi, who cares about the damn decimal point anyway, you guys are like damn chemists! ha
Old Jul 5, 2007 | 07:50 PM
DrivinVtec's Avatar
hahaha..im just wondering. Im planning breaking in the motor at 10psi or so. Thanks
Old Jul 5, 2007 | 09:55 PM
Chris Tune's Avatar
10 psi in a gauge will read about 8 some in the map sensor...
Old Jul 5, 2007 | 11:17 PM
HiProfile's Avatar
Default Re: (Chris Tune)
Its a 1.75bar sensor that gives you the full 1.75bar range and then some. Not many sensors that play a key role will have a range less than what they are rated for.
BTW if it matters, 1.75bar OBD0 MAP's can only read about 10.8psi due to the diaphram being a diff design, OBD1+ MAP's read over 11psi.
Old Jul 6, 2007 | 05:52 AM
ndogg's Avatar
Default Re: (HiProfile)
one problem with pushing a MAP sensor to the limit is you loose the overboost feature. if you are boosting a stock map sensor anywhere over 10psi, you will not have a reliable boost cut.
Old Jul 6, 2007 | 06:23 AM
twkdCD595's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">one problem with pushing a MAP sensor to the limit is you loose the overboost feature. if you are boosting a stock map sensor anywhere over 10psi, you will not have a reliable boost cut.</TD></TR></TABLE>
x2 and you dont want to do that... the boost cut will keep your motor alive if something goes wrong, like a wastegate line coming off or whatnot.
Old Jul 6, 2007 | 07:58 AM
RedR's Avatar
Default Re: (twkdCD595)
was playing with the hondata boost controller last night and i hit the boost cut several times (10.5 psi) on the stock map sensor that is
