stock to Ls-vtec to a turbo
Ok so i went to the integra forum and they told me to go here. Ok this is what i have and this is what i want:
I have a 98 gs with just a cold air intake. 122k miles. Im going to buy a vtec head and a conversion kit. i want to tubocharge my integra to push about 300-350whp.i want to pull around 11-12 1/4 times. what do guys reccomend me doing for me to achieve my goal. Im 16 willing to spend 2k-3k. appreciate the help, btw. its an automatic not a stick
Modified by GsTurbo98 at 11:16 PM 10/30/2007
First off, since I am the first to reply it is my obligation to tell you to USE THE RED SEARCH BUTTON ON THE TOP RIGHT CORNER.
But it is Halloween so heres my opinion :with 2-3k to spend you can def hit 300whp+ all thought at 122k miles i would recommend a rebuild on the block to prevent future problems. A leak down and compression check is a must also. To give you a ball park on power, my LSVTEC set up is very simple. Bone stock B18a1 block with GSR head, 3" down pipe straight to muffler, RC440 injectors, cheap OBX manifold holding a t3/t4 turbo> dyno 280whp at 10psi on a modest tune. Thats just a ball park range. Power will depend on engines condition and size/type of turbo.
Now you to can have the joy of a 300whp honda but only if you convert your auto to a manual. Now you could boost your AUTO but things WILL BREAK. good luck
Do the LS/VTEC, but wait on the turbo setup. You simply DO NOT have the money to do it properly. The LS/VTEC is going to cost around $800-1000 after the oil line kit, headgasket and head itself; therefore, you only have $1-2k to build a turbo setup...good luck. At this point you would also need to convert auto-manual.
Just hold off until you have enough money to build a good setup on your car. Also, since you live in California (aka the worst state in the nation for modifying your car) you're going to have to buy a certain CARB legal kit or face failing emissions testing and inspection...
Billy ramirez
Sep 15, 2017 09:06 AM
blakkvtec
Apr 12, 2010 02:20 PM
joek84
Jan 2, 2004 02:09 PM
