stock fuel lines?
Old Jan 26, 2002 | 05:47 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default stock fuel lines?
does anyone know the exact inside diameter of the stock feed line on a 94-up integra?i am not able to look at it right now and need to know.
Old Jan 26, 2002 | 11:28 PM
turbopimp's Avatar
Default Re: stock fuel lines? (turbotypeR)
Not sure how exact of an answer you're looking for, but a 5/16 " hose barb inserted into the fuel line will be a snug fit...
Old Jan 26, 2002 | 11:58 PM
Giuseppe's Avatar
Default Re: stock fuel lines? (turbopimp)
hmmmm 3/8.??? just guessing its a pretty standard size
hth
Old Jan 27, 2002 | 06:42 PM
25 Year Member
ttt
Old Jan 27, 2002 | 07:35 PM
Jared's Avatar
hondas use 5/16 fuel line on the pressure side.
Old Jan 28, 2002 | 12:59 PM
Dublocivic's Avatar
Default Re: stock fuel lines? (Jared)
Any ideas on what some of the higher hp cars (500ish hp) run for fuel line size? I was going to mount my fuel pump in the engine bay and needed some advice for the feed and pressure side size.
thanks.
Old Jan 28, 2002 | 03:40 PM
89turboteg's Avatar
Banned
Default Re: stock fuel lines? (Dublocivic)
Where do you route the lines if your upgrading your fuel lines to larger stainless steel braided lines? does the same go for nitrous lines? anyone done it? pics?
Old Jan 28, 2002 | 03:55 PM
bigTom's Avatar
Default Re: stock fuel lines? (89turboteg)
higher hp cars mount external pumps generally under the rear of the car somewhere... and ussually -10 an lines are used and are routed somehow undernieth the car... everyone does it a little differant... cant see mine!
Old Jan 28, 2002 | 04:03 PM
Dee's Avatar
Dee
Default Re: stock fuel lines? (Tom)
the stock fuel line is 3/8" while the return line is 5/16"
Old Jan 28, 2002 | 04:32 PM
SEFIxCivic's Avatar
im going to be running -10 AN feed and -6 AN for the return. Dublo, I have an SX fuel pump off my friends race car for sale. In operation for less than 20 miles total. We are going to let it go for a real good price. let me know if your interested.
Old Jan 28, 2002 | 06:55 PM
Gmedalion's Avatar
Default Re: stock fuel lines? (SEFI8LOxCivic)
Where can you get these lines (-10 AN , -6 AN)??
Old Jan 28, 2002 | 07:49 PM
SEFIxCivic's Avatar
Default Re: stock fuel lines? (Gmedalion)
you have to order it from summit and assemble it yourself. getting the lines isnt the problem, its custom fabricating things to fit that cost expensive. a complete fuel system done with AN lines and associated hardware starts @ $1100 and up parts only.
Old Jan 28, 2002 | 11:07 PM
Turbo EG6's Avatar
New User
-10 seems a little extreme. -8 would be more then enough.
Old Jan 29, 2002 | 12:24 AM
SEFIxCivic's Avatar
Default Re: stock fuel lines? (Turbo EG6)
-10 is simpler since it comes out the pump / filter that way.
AWD Terror
Feb 3, 2017 11:59 AM
jdm_h22
Jan 7, 2016 05:58 AM
n1delsol
Jan 20, 2013 03:52 PM
1slwcoupe
Mar 31, 2007 07:59 PM
civickiller
Apr 9, 2004 04:18 AM
