Stock cam vs performance cam
When you turbo a stock motor, why do some people re-install the stock cam? Wouldn't you make more power if you keep the perf cam?
Confused!
Confused!
Confused!
an N/A cam has over lap. a performance N/A cam has ever more over lap. over lap is when bothe exhaust valves and intake valves are open at the same time. so with a turboed car the air would just move straight throught the engine.
Confused!
The air enters the engine the same time the spent exhaust is leaving.
[Modified by Bryson, 12:42 PM 8/8/2002]
Your stock cam will do fine with boost. Idealy, you want a cam with more lift and less overlap/duration to prevent boost from escaping the combustion chamber, this is where aftermarket turbo cams come into play. Crower makes a *supposedly* very good turbo cam for SOHC's, look them up.
there are turbo performance cams though with about the same N/A intake cam and the exhaust cam having alot of lift but very short duration while closing -- thus getting rid of alot of the overlap so air doesn't go right thru the engine.
[Modified by poison, 12:51 PM 8/8/2002]
