still backfiring at low RPMS
Old Apr 15, 2002 | 09:55 PM
turbogsr13z's Avatar
Default still backfiring at low RPMS
why am i backfiring so much i got nre ngk plugs everythin is fien but at low rpms, i backfire one pop every time i shift wuts goin is it my timing?? im boostin 7
Old Apr 16, 2002 | 08:17 AM
teg2snbtrbd's Avatar
Default Re: still backfiring at low RPMS (turbogsr13z)
you might be running too rich. I had the same problem so I leaned out my fuel with my AFC. Do you have a AFC? That could be the problem. Mine always backfired when I let off the gas. IS your check engine light on or coming on?
Old Apr 16, 2002 | 09:45 AM
MDA's Avatar
MDA
New User
You might want to check your exhaust for leaks. Fuel doesn't burn without oxygen. If you're running rich, you should only have excess fuel in the exhaust which is fine, unless you have an exhaust leak. The fast moving exhaust will actually suck in fresh air and cause a potentially explosive combination, hence -> the BackFire.
You can ease back on the fuel so it's not soo rich... but in turbo applications, you always want to be a bit on the rich side... so you'll always have a backfire problem unless you seal up your exhaust.
I've been there... Fixed that.... now im there again.. and about to fix it again... I keep losing my manifold bolts .... hence i get a leak.. and it backfires... i replace the bolts.. and voila... no more backfiring.
bc77711
Honda Civic (2006 - 2015)
Oct 11, 2015 03:41 PM
street_ride14
Apr 22, 2015 01:47 PM
joiv21
Oct 27, 2014 09:38 AM
efjones9
13
Sep 11, 2008 09:01 PM
ScrapinSi
Nov 20, 2003 05:35 PM
