starion incooler options d16.
Old May 28, 2003 | 10:35 AM
platinum00's Avatar
Default starion incooler options d16.
what is the stock inlet and outlet. 2 1/4, ?
for a sohc turbo 10 -15 psi. what do you recommend. ditch the 2 1/4 and upgrade to 2.5, or run 2 1/4 incooler piping troughout, or 2 1/4 to 2.5 transitions.
also anyone have any pics of mounting and piping on a civic ex with greddy kit.
platinum
Old May 28, 2003 | 07:25 PM
scttydb411's Avatar
Default Re: starion incooler options d16. (platinum00)
stock is like 1.75 inch and they are top mounted pipes. i would have them cut/capped and rewelded to at least 2 inch comming out the sides.
Old May 29, 2003 | 01:15 PM
platinum00's Avatar
Default Re: starion incooler options d16. (scttydb411)
any place that can weld aluminum should be able to do this correct.
platinum.
Old May 29, 2003 | 06:17 PM
fsp31's Avatar
>>any place that can weld aluminum should be able to do this correct.<<
I assume that's a question? If so, yes, that's correct. Expect to pay between $30 and $50 per hour + materials. A job like that should cost in the neighborhood of $120.
Old May 29, 2003 | 06:24 PM
TurboJesse
Guest
Posts: n/a
Default Re: starion incooler options d16. (fsp31)
stock is 1.75" , mine are relocated and are now 2.25" it would hard fitting 2.5" in there as teh IC is not that wide.
TurboJesse
Guest
Posts: n/a
Default Re: starion incooler options d16. (Mpir3)
BTW: places around here charge about 75-90 bucks...Although i got mine done for free
Old May 29, 2003 | 06:26 PM
racinskittle's Avatar
Is it possible to do it youself? Any how-to's?
Old May 29, 2003 | 06:38 PM
TurboJesse
Guest
Posts: n/a
Default Re: starion incooler options d16. (racinskittle)
yea if you can weld aluminum good..most people either can't or don't ahve the equipment, luckly my step dad does
Old May 29, 2003 | 08:50 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fsp31 &raquo;</TD></TR><TR><TD CLASS="quote"> Expect to pay between $30 and $50 per hour + materials. A job like that should cost in the neighborhood of $120. </TD></TR></TABLE>
Welding aluminum is expensive... especially TIG
i paid in the neighborhood of $50 to weld brackets on my intercooler and weld 2 aluminum pipes together... fyi
Old May 30, 2003 | 11:17 AM
Hybrid's Avatar
I paid 100 canadian for new 2" end pipes and and four mounting tabs. I don't think thats too shabby hey by.
Old Jun 3, 2003 | 04:38 PM
platinum00's Avatar
Default Re: starion incooler options d16. (Hybrid)
ne1 know of a place in ohio, that i will do this cheap..
platinum.
Old Jun 3, 2003 | 05:11 PM
TRAY's Avatar
Mine came out pretty clean....Its 2.5" in and out. I got it this way
90Rexx
Feb 11, 2010 12:58 PM
EGPHANTOM
Nov 16, 2004 07:54 AM
Firedrake
Dec 25, 2002 12:02 PM
