SSAC turbos........
Old Aug 23, 2006 | 02:43 PM
Jason703Racing's Avatar
Default SSAC turbos........
Ok we all know about the horror post about the glue... BUT... ive talked to 2 recent people that run them for more then a year now and have had no problems. One ran the t3t4 and one ran the t70... Anyone else on here run them or had any other issues?
Old Aug 23, 2006 | 02:47 PM
Danny_EJ's Avatar
Waste of $$$
. /thread
Old Aug 23, 2006 | 03:01 PM
EJ1 wilcox's Avatar
Default Re: (Danny_EJ)
I would like an update on some of the people running them as well.
It seems like we had a bunch of these threads popping up about a year ago about how the SSautochrome turbos are working fine. And a bunch of people were buying them.
I would like to hear from people that have been running them over the past year. Is it possible that they are still holding up??
Old Aug 23, 2006 | 03:16 PM
ryan89crx's Avatar
1+ year with no issues at all. 12psi daily
Old Aug 23, 2006 | 03:26 PM
EJ1 wilcox's Avatar
Default Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">1+ year with no issues at all. 12psi daily </TD></TR></TABLE>
Which turbo? Which vendor?
Old Aug 23, 2006 | 05:26 PM
ryan89crx's Avatar
Default Re: (EJ1 wilcox)
t3 .42/.48
straight from ssauto, XSpower t3
the trick to getting them to last a long time is running an oil restrictor
Old Aug 23, 2006 | 05:36 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">t3 .42/.48
the trick to getting them to last a long time is running an oil restrictor </TD></TR></TABLE>
Old Aug 23, 2006 | 06:25 PM
richieTN's Avatar
just got mine on last saturday and its awsome!! highly reccomended. if you do "search" on the ssac ****,. its all 2 years back, im sure by now they corrected theier problems.
Old Aug 23, 2006 | 06:30 PM
Novtecdohc's Avatar
Default Re: (richieTN)
1 year on 3 diff setup. still working
ps. wreck my car with it on there.
Old Aug 23, 2006 | 06:32 PM
BrokeAssWhiteboy's Avatar
my house has wheels on it
been rinning one the last 9 months. it even survived sucking in one of my old a/c plugs that was just hanging....digested half of it and still no problems
i have been running 15psi on mine ever since i put it on, and i poorly maintained it. still no shaft play or nothing, the only reason i took it off was i bought a bb garrett
Old Aug 23, 2006 | 08:54 PM
ryan89crx's Avatar
Default Re: (BrokeAssWhiteboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssWhiteboy &raquo;</TD></TR><TR><TD CLASS="quote">it even survived sucking in one of my old a/c plugs that was just hanging....digested half of it and still no problems</TD></TR></TABLE>rofl, nice!
Old Aug 23, 2006 | 09:45 PM
pgmatt's Avatar
One .42 .48 T3 5K miles on it working great,one "super T70" not much mileage yet but working great one T25 I used for 2500 miles and sold to someone else and last I heard holding up still and one T3/T4 currently has over 15K miles and has lots of shaft play getting near the end of its life but still building boost.All XS Power directly from SSautochrome I only get knock stuff directly from them and so far have had zero problems with any parts inluding lots intercoolers[really like these],tons of BOV's including the 50mm Tial knock off ,wastegates[double check assembly].I also order my Vband's from them as there only $30-40 I used one mani once but it broke shortly after i sold it as they are complete %100 garbage I know lots of other people using them with very little if any problems but I hear alot of stories of them packing it in so who knows.I will continue to use them as the money I saved i used to buy slicks,traction bars a wideband etc
Old Aug 23, 2006 | 10:20 PM
rev-speed's Avatar
we have a customer with the xs power kit
at 5.5lbs
ls stock
xs power kit
200whp on a dynojet....
it s been a month i wonder how long it will last?
Old Aug 23, 2006 | 10:45 PM
B18C Turbo's Avatar
Mine is still going after 1.5 years, 6psi daily driven. If Jeff Evans from Evans-tunign supports the stuff why doesnt everyone?
Old Aug 24, 2006 | 01:42 AM
dayne808's Avatar
i have a kit and have yet to have it tuned. my only problem so far is my snail doesn't have the vacuum fitting on it!
Old Aug 24, 2006 | 06:36 AM
200cs's Avatar
Default Re: SSAC turbos........ (Black00em1)
I bought one almost two years ago without doing any research However I decided to use it anyway as I had already spent too much going to the dark side....
It has been in the car since Feb-05 and has been problem free. I expected it to die a long time ago and then replace it with a Garret, but it just won't die!
I wouldn't recommend one as I had all kinds of problems with their manifold but the one I have has been a good unit. Go figure!
Old Aug 24, 2006 | 07:25 AM
Boner_Ben's Avatar
Default Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Mine is still going after 1.5 years, 6psi daily driven. If Jeff Evans from Evans-tunign supports the stuff why doesnt everyone?</TD></TR></TABLE>
Does he have the final say these days???
Old Aug 24, 2006 | 07:44 AM
blackdude's Avatar
running one of the 57 trims for 2 years 16 psi 420hp on an lsvtec piston rods 9to1 comp no problem 25k miles has some shaft play but using it until it blows
Old Aug 25, 2006 | 11:41 AM
1990hondaHF's Avatar
Need some serious info on this....I'm planning on buying on of those soon for my GSR/CRX.
Old Aug 25, 2006 | 11:53 AM
93CX's Avatar
Default Re: (1990hondaHF)
Bought mine used with 10k miles on it. No shaft play, BOV, WG, manifold, IC, all holding up fine.
Old Aug 25, 2006 | 02:53 PM
Default Re: (93CX)
Now im debating, T3T4 57 Trim 8-10psi on my stock b16a or... building a b18b with a b16 or gsr head (lsvtec) with rods/pistons 8:5:1 or 9:1 compression and running there t-70 with a top mount manifold insted of the ram horn im planning now..
Either way i plan on really thinking it over as i have 4 months to decide how i want to plan this out. Either way im ordering my intercooler, piping, bov from S-FAB and from there ill plan the manifold,down pipe, turbo and motor setup.
Brad (sfab) ran the t70 on a 2.0l ls and went 11.0 said from 5k on it was nuts and im considering going this road. Or ill leave the car as a daily and run there t3t4 57 trim on a ram horn manifold and just be happy.
so many choices...
Old Aug 25, 2006 | 03:39 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">Need some serious info on this....I'm planning on buying on of those soon for my GSR/CRX.</TD></TR></TABLE>search ebay for "Function7" im using their t3 oil inlet flange/restrictor
Old Aug 25, 2006 | 03:43 PM
Dee's Avatar
Dee
Are we supposed to give a flying apeshit about which parts are approved by Jeff Evans??
Old Aug 25, 2006 | 04:32 PM
pgmatt's Avatar
Default Re: (Dee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">
Are we supposed to give a flying apeshit about which parts are approved by Jeff Evans?? </TD></TR></TABLE>
Yes.This is Honda Tech remember where nut swinging was invented.
Old Aug 25, 2006 | 05:13 PM
rickturboteg's Avatar
Default Re: (pgmatt)
600miles on my xs power/ssac turbo with restricter and intercooler with no problems whats so ever..
