spudder when vtec engages
Old Apr 1, 2015 | 11:05 AM
John Ackerson's Avatar
Default spudder when vtec engages
I was getting my car tuned with crome and when vtec engages the engine shudders like a rev limiter. No matter what rpm we set vtec at it does the same thing. The car pulls hard until vtec engages.
Old Apr 1, 2015 | 12:55 PM
turbohatch96y7's Avatar
You provided so much info idk where to start
Spark blow out?
Old Apr 1, 2015 | 12:58 PM
$amGD3's Avatar
Swaggylicious
Default Re: spudder when vtec engages
mmmmm spuds
Old Apr 2, 2015 | 06:22 AM
LightningTeg's Avatar
Community Builder
Cams? Turbo? Exhaust Manifold? Tuner?
Old Apr 28, 2015 | 09:08 AM
Bump because I still have this problem. When Vtec is supposed to kick in the ecu throws a code 21 for vtec solenoid. We have replaced the solenoid and made sure the wiring is good to the ecu. I believe it has to do with oil pressure because vtec was working before I installed the turbo.I have the oil feed line teed off at the oil pressure sensor. Could I need a smaller restrictor for the turbo?
Old Apr 29, 2015 | 07:14 AM
hardcore97's Avatar
what engine? i know if you had the head apart and had the rods that the rocker arms sit on out and you dont put them back on the right side(intake and exhaust) the car will act retarded when trying to go into vtec because the oil holes dont line up with the holes in the rocker arms and it wont pressurize and lock the pins correctly
Old May 23, 2015 | 01:39 PM
B18c1. We didn't have the motor apart. Vtec worked before I boosted it.
Old May 23, 2015 | 04:18 PM
NotARaCist's Avatar
I never narc'd on nobody!
Your tuner doesn't know how to diagnose this? Or did they tune it, give it back to you, and then this problem started?
Old May 23, 2015 | 11:18 PM
He said to put an oil line to the head. I just wanted to see if this has happened to anyone else.
Old May 24, 2015 | 03:14 PM
TheShodan's Avatar
Moderator
Oh boy.. This won't end well
Old May 25, 2015 | 12:32 PM
Why? Do you have any other suggestions? Already checked the vtec solenoid.
Old May 26, 2015 | 03:33 AM
g.t engineering's Avatar
oil pressure *
Old May 26, 2015 | 04:11 AM
NotARaCist's Avatar
So, let me get this straight. VTEC wasn't working, but the tuner tuned your car anyway, and told you to "just hook up an oil line"? There was no "hook up an oil line, then bring it back"? He couldn't have tuned you on the VTEC lobes if VTEC wasn't actually working, so it sounds like either your tuner gave you shoddy advice, or you didn't actually listen to what they said.
Old May 26, 2015 | 07:05 AM
mangina's Avatar
Do you own a red integra? Racing it sunday at fayetteville dragstrip?
Old May 26, 2015 | 07:56 AM
Turbo-LS's Avatar
WOW. That is all .......
Old May 26, 2015 | 05:39 PM
Muckman's Avatar
Moderator in Chief
Why would your tuner say to hook up an oil line to the head? Its a GSR engine not an LS/VTEC. Wow..
Old May 26, 2015 | 08:54 PM
NotARaCist's Avatar
Muck, I'm guessing it's my previous "option B". The tuner told him something, but OP didn't actually listen.
Old May 27, 2015 | 05:00 AM
D-Rob's Avatar
THAT is the most true statement I have read on H-T in a while.
Old May 27, 2015 | 08:30 PM
preludedude2001's Avatar
Hi. sorry. new at this. anybody wire in an aem f/ic 6 piggy back? Wondering about wiring the crank and cam sensors. thanks for any help. Dan
Old May 28, 2015 | 01:26 AM
NotARaCist's Avatar
Dude, holy ****. 10 posts, 7 of which are attempted threadjacks? How have you not been banned yet?
Old May 28, 2015 | 04:13 PM
Whats the proper way to start a thread?
Old May 28, 2015 | 04:43 PM
NotARaCist's Avatar
Are you dense, or just stupid? You didn't come anywhere close to "starting a thread". You posted on someone else's COMPLETELY IRRELEVANT thread. Read the rules sticky. Then read the FAQ sticky. Then, if your question hasn't been answered, and you have put in the effort to find answers, and ONLY then, do you click that button on the top left of the subforum listing labeled "New Topic".
If this is any indicator of the forethought you put into your car, I can't wait to see the abortion you come up with.
Old May 29, 2015 | 02:12 PM
Dude.. youre ignorant. and im going to report it. get a life! This is supposed to be a sight to help.eachother, not abuse.
Old May 29, 2015 | 02:27 PM
NotARaCist's Avatar
Aw, how cute. You must be new here. Here, I'll give you a welcoming party. Complete with a cat!
Now let me explain something to you. You came into our house. You shat on the floor. You pissed on our dog. Now, after that, you expect us to be nice to you. Go back to school, learn how to properly use the English language, learn some basic forum etiquette, and then come back and give this whole thing another go. When you do come back, don't shitpost on someone else's thread - make your own, and maybe if you're lucky we won't remember how much of a winging little **** you've been, and you'll get some help. You try to steal someone else's thread with your completely unrelated bullshit, this is exactly the kind of response you deserve.
Old May 30, 2015 | 08:08 AM
Ill bet you spend all your time on here cause you dont have a single friend...loser. Funny how you chose a cat.. *****!
