Spraying nitrous
Old Nov 23, 2004 | 07:06 PM
TeenyTymer69er's Avatar
Default Spraying nitrous
Should i spray in 1rst when at WOT with just i/h/e? I have a 97 civic ex with greddy exhaust, dc headers and aem cold air intake with 55 shot of nos.
Old Nov 23, 2004 | 07:16 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Spraying nitrous (TeenyTymer69er)
id spray at WOT after the power kicks in, like roun 3500rpm when your clutch is totally engaged, then use it in 2nd, cause first gear goes kinda fast, use it most in 2nd and 3rd for that car.
Old Nov 23, 2004 | 07:46 PM
Tuesday Club's Avatar
Default Re: Spraying nitrous (Redline96LX)
You can launch w/ nitrous in any gear HOWEVER I would recommend keeping the rpms at or above 3500 at all times. DO NOT spray at or below 3000...this can cause problems: the engine isn't spinning fast enough (lay-man's terms) to compensate for an instantanious power boost and can/will cause nitrous backfire etc.
But most of all, have fun
Old Nov 23, 2004 | 08:44 PM
DC2Slow's Avatar
Default Re: Spraying nitrous (mercuryfrost)
what he said
Old Nov 23, 2004 | 09:57 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: Spraying nitrous (DC2Slow)
newb's on nitrous in 1st gear usually hear the rev limitor.. so i would recommend 2nd and on..
if you have the traction and reaction time of shifting in 1st on the bottle, ide go for it... if not, stick to the longer gears.
not to brag, but my track car is a fully built b16 on 100 shot, slicked down, i can squeez out of the hole, and run 12.5's... i can't even watch the tach, its more of hearing, and knowing when its time to shift.
Old Nov 24, 2004 | 06:53 AM
DC2Slow's Avatar
Default Re: Spraying nitrous (Built B16A)
is that at LACR?
Old Nov 24, 2004 | 08:30 AM
Honda_Tengoku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeenyTymer69er &raquo;</TD></TR><TR><TD CLASS="quote">Should i spray in 1rst when at WOT with just i/h/e? I have a 97 civic ex with greddy exhaust, dc headers and aem cold air intake with 55 shot of nos.</TD></TR></TABLE>
if u are running a Honda ECU do not under any circumstances hit the Honda rev limiter on spray. The rev limiters cuts fuel. So if u are on spray in first gear and dont catch it b4 the limiter, then u just ran your engine lean. Not good at all. Best bet 2nd, 3rd and 4rth gear on spray only
Old Nov 24, 2004 | 08:33 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A &raquo;</TD></TR><TR><TD CLASS="quote">newb's on nitrous in 1st gear usually hear the rev limitor.. .</TD></TR></TABLE>
LOL..
SunriseSunset
Honda Civic (2001 - 2005)
Apr 28, 2017 02:25 AM
The7thG
Feb 8, 2007 06:09 PM
Royal_C!ty
Oct 28, 2005 11:25 AM
f23accord
Nov 9, 2004 12:46 AM
GoodFella
Jul 25, 2001 07:12 PM
