Spoolin performance?
Old Mar 23, 2009 | 03:45 PM
poppypizza's Avatar
Default Spoolin performance?
has anyone used there downpipes with a ramhorn manifold? It says the downpipes are only suppose to be used with their manifolds. Im in need of a downpipe that goes under the low side of the oil pan,, closer to the tranny. Or the left side if your standing in front of the car, if that makes sense. Has anyone used the ebay ones? or do they also break? any help is good help!
Old Mar 23, 2009 | 06:11 PM
TheShodan's Avatar
Moderator
Default Re: Spoolin performance?
Spoolin performance, like most companies, have their downpipes match to THEIR manifolds. This is to ensure a better fitment from the same Jig. Using Ebay, or other "universal" downpipes may run the risk of you not being able to fit both your turbo and manifold in the correct spot. This is to say that whatever manifold you have, use the same company downpipe to match, or have your own made to be perfectly sure.
Old Mar 23, 2009 | 06:18 PM
95BoostedEJ1's Avatar
i got there downpipe and it looks amazing..fit perfect..
Old Mar 23, 2009 | 10:17 PM
poppypizza's Avatar
well i bought my ramhorn from a fellow h-ter and he says it was made by CoreyR from h-t,, 95BoostedEJ1 what side does yours come off? Ac compatible or not?
Old Mar 23, 2009 | 11:14 PM
SD_Lurker's Avatar
HT White Ops
Well then your best bet is to contact CoreyR and see if he will make you a matching downpipe. Also, unless its a side exit all DP are routed the same way, under the smaller section of the oil pan.
Old Mar 24, 2009 | 12:40 AM
poppypizza's Avatar
okay thanks,, I dont really know what a side exit dp is but im looking it up. And i did contact coreyr
StuG_Lyfe
Oct 28, 2014 08:31 AM
stocker2shocker91
Oct 7, 2009 02:07 AM
ef9hatch
Jun 1, 2006 06:44 PM
int3gra
Jul 24, 2003 03:42 PM
