Spool time with a 14B
Old Jan 2, 2003 | 05:05 AM
BorderM3's Avatar
Default Spool time with a 14B
I have a D16 with right around 9.8:1 compression.
I had what i believe to be a crane stg 2 cam in it(N/A cam) I was spooling 8lbs right around 3800rpm. I figured i would swap out the crane for a stock cam and drop a few thousand rpm on the spool. This didnt happen, and the car feels slower....maybe its just in my head?
I figured the duration for a stg 2 n/a cam would be detrimental to performance with a turbo application.
PS the cam was in a car i bought, rumor has it, it was a stg 2 crane. It has some sort of marking on the distributor end of the cam.
Is spooling 8lbs @ 3800rpm bad??? Sounds shitty to me when having the kind of compression i do.
[Modified by BorderM3, 2:06 PM 1/2/2003]
Old Jan 2, 2003 | 06:03 AM
BorderM3's Avatar
Default Re: Spool time with a 14B (BorderM3)
Anyone else have a 14b on a SOHC what rpm do you spool???????? TTT
Old Jan 2, 2003 | 08:09 AM
BorderM3's Avatar
Common LADIES!!
Old Jan 2, 2003 | 09:25 AM
redline's Avatar
my friend has one a 92 si hatch and he hits 8psi by 3000rpm and it is stock engine with a junk yard setup.
SOHC_MShue
Apr 18, 2021 10:26 AM
michaelprice83
Sep 16, 2010 06:15 PM
Screaming
Jan 30, 2006 08:59 PM
W0oT
Oct 4, 2001 10:07 AM
