Speedfactory MAP installed - No Start
Old May 6, 2012 | 05:00 AM
dglassmyer's Avatar
Default Speedfactory MAP installed - No Start
Hey guys, I'm working on a 1996 Accord with an F22b1 and just installed a speedfactory 4 bar map sensor as Im soon going to turbo the car.
The issue is, with the new MAP installed, it just won't start.
Are these maps not compatible with a stock ECU?
I'm concerned as I bought this used off a forum member and hope I didnt hosed on the deal.
Old May 6, 2012 | 05:25 AM
david974's Avatar
Default Re: Speedfactory MAP installed - No Start
no they aren t compatible with stock ecu, you must be tuned
Old May 6, 2012 | 05:30 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
you have to have the tuner set the map for the new MAP sensor
Old May 6, 2012 | 05:39 AM
dglassmyer's Avatar
I was hoping that would be the case, I have an s300 that will handle ecu duties and will wait to install it then.
Thanks for the clarification and quick responses.
Old May 6, 2012 | 06:13 AM
hussain-vtec's Avatar
Set up the map sensor to 4 bar Haondata map sensor in the s300 program, speed factory 4 bar map is working on the same voltage as Hondata 4 bar map.
Or get it to the nearest tuner here you go tuner directory link below.
https://honda-tech.com/forums/engine-management-tuning-124/tuner-directory-2368887/
ekk41
Oct 24, 2007 05:28 PM
KRWTEK1
May 28, 2007 12:32 AM
SpoolnByYou
Dec 24, 2005 02:35 PM
BEASTLY
Feb 26, 2004 01:27 PM
CiViC SiR
Jul 7, 2003 02:55 PM
