sparkplug help
Old Feb 24, 2003 | 11:11 PM
turbospool's Avatar
Default sparkplug help
Hi, should i run 2 step colder or 1 step colder plugs for 9psi? I have full MSD ignition and i have a 12:1 FMU stock injectors with walboro 255 hp pump. Rev Hard 2c kit.
Is it bad to run too cold of a plug? other than fouling...thanks
Old Feb 25, 2003 | 09:52 AM
b16ahybrid's Avatar
Default Re: sparkplug help (turbospool)
2 steps will be fine. So just run a heat range of 7.
Old Feb 25, 2003 | 04:22 PM
turbospool's Avatar
Default Re: sparkplug help (b16ahybrid)
does anyboyd know the part number for 2 steps colder ngk plugs on a B18B?
Old Feb 25, 2003 | 05:05 PM
98civicEX's Avatar
ngk bkr7e
Old Feb 25, 2003 | 06:05 PM
zojirushi's Avatar
for a b18b, it should be zfr7f-11
Old Feb 25, 2003 | 11:37 PM
turbospool's Avatar
Default Re: sparkplug help (zojirushi)
so is it the zf or the bk?
[Modified by turbospool, 8:37 AM 2/26/2003]
Old Feb 26, 2003 | 09:27 AM
mstsh80's Avatar
what plugs should i run on a h22a 8 lbs drag kit, i am currently running stock platinum, is that bag, it runs great, gas milege is horrible
Old Mar 2, 2003 | 07:49 PM
turbospool's Avatar
Default Re: sparkplug help (spoolin22)
so is it ZF or BK for B18B LS motors?
Old Mar 2, 2003 | 11:05 PM
turbospool's Avatar
Default Re: sparkplug help (evan2)
i know, i want to kno which NGK's are 2 step colder for the b18b
Old Mar 2, 2003 | 11:10 PM
earl's Avatar
Do a search. I just posted a NGK chart a few days ago.
Old Mar 2, 2003 | 11:28 PM
boostaholic's Avatar
I've ran both the bcpr7es and bkr7e in my LS motors and they both do fine.
Old Mar 3, 2003 | 05:21 AM
mskibbz-T's Avatar
Old Mar 3, 2003 | 10:26 AM
BubRub's Avatar
do you gain/lose any hp using 2 step colder plugs compared to just 1 step colder?
pros and cons of 2 step VS 1 step colder plugs?
Old Mar 3, 2003 | 12:13 PM
alpha's Avatar
Default Re: sparkplug help (earl)
https://honda-tech.com/zerothread?id=428343
R.S.
24
Jan 5, 2005 09:08 PM
chuckd05
Apr 3, 2003 08:37 AM
pub
Mar 26, 2003 08:20 PM
E Swift
Sep 2, 2002 06:46 AM
