Spark Plugs
So I'm going to start up the beast for the first time tommorow and I'm wondering what I should gap my spark plugs at.
I'm only going to be running ~7psi for the time being. What do you guys run?
Setup:
te04h turbo
log manifold
2.5" charge piping
d15b7 w/ uberdata
450cc dsm's
So yea, what do you guys run?
Setup:
te04h turbo
log manifold
2.5" charge piping
d15b7 w/ uberdata
450cc dsm's
SO the stock plug for the d15b7 is the zfr5f11
I'm wondering if NGK makes ZFR6F11's? As i understand that would be one step colder?
I can't seem to find any colder plugs in my area. Suggestions?
Your going to have to special order them. Stay away from platnum and iridium plugs on a boosted car.
https://honda-tech.com/zerothread?id=510127
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Your going to have to special order them. Stay away from platnum and iridium plugs on a boosted car.
https://honda-tech.com/zerothread?id=510127</TD></TR></TABLE>
I still don't understand why you can't use iridium's, they have a higher heat
rating then the v-powers. I understand that copper is a better conductor but
with the smaller point and the correct heat range I can't see the spark
being that much different. Is there actual proof of why not to? Or is it hear
say?
say?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR »</TD></TR><TR><TD CLASS="quote">
say?</TD></TR></TABLE>
I know you don't use the platinum becuase it gets super hot and can cause detonation. I would imagine that iridium is the same way. The reason they work so good is how hot they get.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Overblown-Teg »</TD></TR><TR><TD CLASS="quote">
I know you don't use the platinum becuase it gets super hot and can cause detonation. I would imagine that iridium is the same way. The reason they work so good is how hot they get. </TD></TR></TABLE>
But the iridiums are made for hot applications the heat rating is alot higher
then the standard ngk's.
then the standard ngk's.</TD></TR></TABLE>
Right so are the platinum. The problem is the tip gets really hot. It becomes a hot spot in the combustion chamber and can cause detonation.
