spark plugs
running a gsr stock t3t4 turbo, what kinda spark plugs you use cause my friend melted his spark plug onto the head. i'm running bosch duel platinum, are they okay?? where can i find better.
Oops, sry about the typo. BKR7E-11s drop right into B18cs... but for turbo applications the .40-.44 gap thoase 11s come with is too big. Regap to something closer to .30.
yea i just gaped them to about .305 and does the curve have to be flat with the gap cause mines is slanted where the gap there is exactly .305mm. i just put them in and it mis fires every other cycle. put my duel platinums back in and ran fine. any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teddy_dc2 »</TD></TR><TR><TD CLASS="quote">yea i just gaped them to about .305 and does the curve have to be flat with the gap cause mines is slanted where the gap there is exactly .305mm. i just put them in and it mis fires every other cycle. put my duel platinums back in and ran fine. any suggestions?</TD></TR></TABLE>
There any difference in the gapping between the 2 that are missing and two that are firing. Doesnt make much since to me. Sounds like something isnt connected right.
Use a gapping tool and then tap the plug down softly. Mine tend to end up a little slanted but work just fine.
Can you snap a picture of the plugs? Closeup of them would be useful.
i gapped to .012 or .305mm and everyother cylinder would mis fire, seems like barely any room to spark. so i gap to the bigger .03 or .763mm and ran fine all except sparks doesn't seem powerful at high rpms like my duel platinums. is the gap correct?
CaptainBuster
Oct 1, 2014 09:38 AM
