Spark Plug Gap???
Old Nov 19, 2004 | 01:01 PM
  #26
b00stedbyFastrax's Avatar
Default Re: (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">On high boost we've had to go down to 0.018" (seems insanely tight huh) but in general anywhere from 0.022-0.030" even with higher power 150mJ+ ignitions.</TD></TR></TABLE>
that is where i am also.
Old Nov 19, 2004 | 04:34 PM
  #27
hatchback_al's Avatar
Default Re: (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sway892 &raquo;</TD></TR><TR><TD CLASS="quote">.030 is whats recommended when boosting, and make sure you get NGK's
BCPRES-11. They're cold spark plugs and I love them. </TD></TR></TABLE>
Is that spark plug code for b series motors, or d series? Does it even matter? Do they use the same plugs??
Old Nov 19, 2004 | 04:39 PM
  #28
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (hatchback_al)
i run bosch 7553's on my turbo zc. there a step colder than stock plugs and there only a dollar a piece. i also gap them .30
Old Jun 4, 2008 | 07:54 AM
  #29
accord_raffi's Avatar
Default Re: (The Hooligan)
i'm almost done with my boosted accord...my tuner linked me to the R5671A-7's. I'm going to try gapping them at .030 and see what luck i have. A lot of the motors spoken about here are smaller than mine but i'll see what luck i have
Old Jun 4, 2008 | 07:57 AM
  #30
evosix's Avatar
Default Re: (accord_raffi)
anyone know what the factory gap should be on a stock naturally aspirated LS motor?
Old Jun 4, 2008 | 12:03 PM
  #31
inspyral's Avatar
Default Re: (evosix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evosix &raquo;</TD></TR><TR><TD CLASS="quote">anyone know what the factory gap should be on a stock naturally aspirated LS motor? </TD></TR></TABLE>
1.1mm or 0.043"
Old Jun 6, 2008 | 05:01 AM
  #32
HondaKyle's Avatar
Default FV-QR
OEM GAP FTW!
Old Jun 6, 2008 | 06:56 AM
  #33
purpleh22's Avatar
Default Re: FV-QR (HondaKyle)
H22, NGK 7s, 10:1, 18 psi - - - .28 gap.
Old Jun 6, 2008 | 02:04 PM
  #34
88ED8's Avatar
NGK 7's @ .30 & stock ignition system...
Old Mar 6, 2009 | 05:24 AM
  #35
northemt88's Avatar
Default Re: Spark Plug Gap???
im running .32 on ngk.LS turbo it idles and runs perfect
Old Mar 6, 2009 | 06:01 AM
  #36
dpetro1's Avatar
works for both. might be a bit cold for a d-series, depends on the power level.
non-resistor plugs are not reccomended for our cars. see this article from hondata http://www.hondata.com/techksparkplugs.html
Old Aug 13, 2009 | 11:19 PM
  #37
Grimvamp101's Avatar
How do you know what plugs to run if you never boosted before? not to mention if you don't know how much hp your motor will make after tune? i always run NGK's (i trust them the most), how do you know when you need to go colder or hotter?
Old Aug 14, 2009 | 04:31 AM
  #38
postman's Avatar
.034 on my setup, b16 at 9lbs. few thousand miles of great driving. generally but not always the larger the gap u can run the better. just have to watch for blowout.
Old Aug 14, 2009 | 04:41 AM
  #39
dpetro1's Avatar
http://www.ngk.com/glossary.asp?kw=H...+hotter+plug?&
what is your setup, im sure we could give you an hp estimate or recommend a plug based off what turbo and how much boost you plan on running. generally you can use 7's up to 400whp then might want to step up to 8's in the 450-500 range
Old Aug 14, 2009 | 05:18 AM
  #40
Tjabo's Avatar
Originally Posted by Garcia-Racing
ngk 8's @ 0.026
I have a hard time finding copper 8s, so I'd love it if you could post up some more information on what this plug is?!?! If it's the Iridium 8, then that's cool, but I can get Iridium 9s, and those are fine when I'm spending the big bucks! Hah hah. . .
Thanks in advance!
Old Aug 14, 2009 | 06:51 AM
  #41
dpetro1's Avatar
Thanks in advance!
pretty sure they dont make a copper 8, just the iridiums or non-resistor racing plugs.
Found this on another forum from 2006, someone asking about a bkr8e stock number
Originally Posted by NGK
Hello,
Use a BKR8EIX stock number 2668. We do not produce the BKR8E v-power
nickel alloy version.
Jon MacQuarrie
Technical Support Specialist
NGK Spark Plugs (U.S.A.), Inc.
46929 Magellan Drive
Wixom, MI 48393
(248) 926-6313 Direct Dial
(248) 705-1485 Cell
(248) 926-6938 Fax
Old Aug 14, 2009 | 08:49 AM
  #42
Tjabo's Avatar
Thanks man, I think that pretty much explains it then!
Just to make sure, I'm assuming they don't make a cheap version (looks like copper isn't correct from that last post, nickel alloy I guess?) of a 9? BKR9E? ? ? THAT would be SWEEEEEEET!
Old Aug 14, 2009 | 10:23 AM
  #43
dpetro1's Avatar
unfortunately it looks like its just the iridiums for the 9's too. what setup are you running that requires 9's?
Old Aug 14, 2009 | 11:04 AM
  #44
4drdohc's Avatar
bkr7es-11 .30, idle perfect
Old Aug 14, 2009 | 12:14 PM
  #45
blackeg's Avatar
it all depends on your boost pressure, ignition system etc.... you cant just say run .030" for turbo.
most stock motor turbo setups in the 10psi range i run .026-.028 gap.
my 425hp car last year ran bkr7e's gapped down to .020" on a bone stock ignition and plug wires.
Old Aug 14, 2009 | 01:16 PM
  #46
93CX's Avatar
Lol at people running stock gaps back in 2004..
BKR7E @ 0.026 here perfect idle
Old Aug 14, 2009 | 02:59 PM
  #47
Tjabo's Avatar
Same here, actually anywhere between .026-.028" is what I've been running, mostly with these plugs, and my idle is as perfect as my tune will let it be on any given day (always changing it! LOL).
As for the 9s, I don't really need them, but I'm running a stock Neon bottom end right now, and they are known for liking to blow up around 250 ft/lbs., so I'm trying hard to avoid detonation and keep my luck on the good side.
Once I finally get around to getting the good bottom end put together I will push my luck with a lot of boost, so I'll still want 9s! They run perfectly for me, they're just expensive.
Oh, and for the people who are running the -11s, they just start out with a 1.1mm gap, which means you have to ungap them more. Doesn't make sense to me. . .
Old Aug 17, 2009 | 09:16 AM
  #48
Dubs13's Avatar
How much boost are you running? I'm planning on gapping mine to exactly that seeing as I'm only running 7psi.
Old Dec 1, 2009 | 07:41 PM
  #49
99kleansi's Avatar
A little more info on the miss at idle please anyone. Im running 15 lbs on ngk7 gapped at .29. I have changed my distributor cap and rotor any one have any ideas? Its just kinda annoying rather then any effect on my performance ive noticed.
Old Nov 22, 2010 | 03:01 AM
  #50
JDM B20 EH2's Avatar
I see everyone runnin 7's with higher boost/hp cars. I'm just goin to be runnin a d16z6 with around 10-12psi. Would this still be the right plug and just play with gap or use a diff plug?
