Some updates
Old Aug 30, 2005 | 11:09 PM
K20 SDN's Avatar
Default Some updates
Coming out really soon....
Sponsering this project.
I really want to thank Keven, Kitty, *****y, and Gearhighms at AutolinkMotorsport for helping and doing a very good job with my project and they have always helped on every project that I've done . I want to thank JDMAutoHaus for the parts and Victor for being a very big help ,GoldenEagle for the sleeves,Exedy Japan for a custom thriple plate clutch and Bubba at Do It Dyno for His dyno time.
The motor is going in 8/31/2005 and we should be able to start it on 9/3/2005
SPEC SHEET/PARTS LIST
CHASSIS
- 1990 Nissan 240SX (Silvia)
- Nismo Motor and Tranny Mounts
- Promod Custom 12-point roll cage
- Fuel Safe 15 gallon fuel cell
- Weldon fuel pump 2115
- Weldo fuel pressure regulator
- JDM S13 rear end w/4.10 final drive and custom oversize axles, Kaaz two-way limited slip
- Cannon Engineering custom drive shaft
- New OEM wire harness
- Stack digital dash cluster ST8130
ENGINE - SR20DET
- HKS Cams stage 3
- HKS Lash killer kit ( solid lifter kit )
- Greddy Valve Springs
- Crower Retainers
- Ferrea Custom Valves
- Greddy Rocker Arm Stoppers
- Greddy Adjustable Cam Sprockets
- Cylinder head square ported and polished by Mo Flo
- Apex’I 87mm head gasket
- Greddy 87mm pistons & rings
- Greddy rods & wrist pins
- Golden Eagle sleeves
- New OEM Oil Pump
- New OEM Rear Main Seal
- ARP Main Bolts
- Greddy Head Studs
- Greddy Oil Pan
- OEM Main and Rod Bearings
- Exedy triple plate carbon clutch kit
- B&M short shifter
- Nismo shifter
- Skyline brake & 5 lug conversion
- Greddy Electronic Boost gauge
- Greddy Electronic oil pressure gauge
- Greedy Electronic EGT gauge
- Greedy Electronic Boost controller
- Greddy Turbo timer
- Greddy Intake Manifold (ported by Mo Flo) w/custom 90mm throttle plate, Q45 throttle body
- Greddy Oil pan
- Custom Full-Race stainless turbo manifold
- Custom Fuel Rail
- Rochester 1600cc Injectors
- SplitFire Coil Pack
- Garrett GT40R dual ball bearing turbocharger
- 44mm Tial Wastegate
- 50mm Tial Blow-Off Valve
- Full-Race Custom 4” stainless down pipe
- Full-Race Custom stainless dump tube
- Full-Race Custom stainless exhaust manifold
- Apex’I GTR Intercooler Core
- Apex’I 3” IN Tanks
- Burns 3" aluminum intercooler U bend piping
- Meziere electric water pump
- Koyo radiator
- Dual FAL fan's
- Blitz upper radiator hose
- Samco lower radiator hose
- Cosworth 3-bar MAP sensor
- AEM EMS engine management
- AEM WEGO wide band a/f sensor w/gauge
Modified by jdmej20 at 12:30 AM 8/31/2005
Old Aug 30, 2005 | 11:33 PM
jarel's Avatar
good ****! seen the motor in person a couple of times, very nice piece of work.
Old Aug 31, 2005 | 12:06 AM
714phil's Avatar
Nice pics. Is this your street car you will be driving daily? what are the intentions of building this car? Any HP goals or anything of that nature?
Old Aug 31, 2005 | 12:37 AM
94_HATCH's Avatar
Default Re: Some updates (jdmej20)
cant see pics....sounds nice though
Old Aug 31, 2005 | 06:17 AM
K20 SDN's Avatar
Default Re: (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">Nice pics. Is this your street car you will be driving daily? what are the intentions of building this car? Any HP goals or anything of that nature?</TD></TR></TABLE>
Yes, I will drive it on the street and HP goal 750+.
This is an all around car
Not for drifting.
There is alot more being done to the car. I will post pic's and post a video of it also
Old Aug 31, 2005 | 06:35 AM
11psiTurboSI's Avatar
Default Re: (jdmej20)
Nice
Old Aug 31, 2005 | 06:43 AM
Adam.C's Avatar
sweet, just sweet
Old Aug 31, 2005 | 08:14 AM
MR.M's Avatar
Default Re: (jarel)
I'll give this a car a UP...
Old Aug 31, 2005 | 08:18 AM
txsynergy's Avatar
Default Re: (K_Motor)
Old Aug 31, 2005 | 08:31 AM
K20 SDN's Avatar
Reason why the doors are off the car is because we are also getting a set of VIS doors with the trunk and vented hood in carbon
Old Aug 31, 2005 | 08:33 AM
LaXcAt's Avatar
Default Re: (txsynergy)
sick
Old Aug 31, 2005 | 09:28 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmej20 &raquo;</TD></TR><TR><TD CLASS="quote">Reason why the doors are off the car is because we are also getting a set of VIS doors with the trunk and vented hood in carbon
baller..show some pics when done
Old Aug 31, 2005 | 06:10 PM
K20 SDN's Avatar
Default Re: Some updates (Rod.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">
baller..show some pics when done</TD></TR></TABLE>
Sooon
Old Aug 31, 2005 | 08:59 PM
GOGOMAIS's Avatar
Wow, that's some hard ****. HARD *** **** YO! I saw a similar swap near Harvard university once. Although his oil pan looked different this oil pan looks mean as a ****!
Old Aug 31, 2005 | 09:13 PM
nfn15037's Avatar
Default Re: Some updates (GOGOMAIS)
This isn't a drift car, is it? Nice work though, very clean!
Old Aug 31, 2005 | 09:46 PM
SHystrdyGSRtdy's Avatar
Default Re: Some updates (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">This isn't a drift car, is it? Nice work though, very clean! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmej20 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I will drive it on the street and HP goal 750+.
Not for drifting.
There is alot more being done to the car. I will post pic's and post a video of it also</TD></TR></TABLE>
wow man.. i wanna check out the car when it's done... looks VERY nice! bet it sounds even better
Old Aug 31, 2005 | 09:58 PM
GOGOMAIS's Avatar
Default Re: Some updates (SHystrdyGSRtdy)
HARDEST **** SINCE NICK CARTER LEFT BACKSTREET!
Old Aug 31, 2005 | 10:03 PM
MR.M's Avatar
HELLOOOO NO..Not a drift car...
Thank you...
Old Aug 31, 2005 | 10:07 PM
af-performance's Avatar
Banned
Default Re: Some updates (K_Motor)
AF-P loves Nissan's
Beautiful Setup you have there. Best of luck.
Old Sep 1, 2005 | 06:44 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K_Motor &raquo;</TD></TR><TR><TD CLASS="quote">HELLOOOO NO..Not a drift car...
Thank you... </TD></TR></TABLE>
No, thank YOU for not participating in automotive figure skating with a beautiful car like that!
Old Sep 1, 2005 | 06:52 AM
Full-Race Javier's Avatar
nice , it's almost a rwd version of my se-r good to see someone else running a GT40 on a SR
Old Sep 1, 2005 | 07:06 AM
MR.M's Avatar
No, thank YOU for not participating in automotive figure skating with a beautiful car like that!</TD></TR></TABLE>
Thank you...
Old Sep 1, 2005 | 07:50 AM
JDM_Risa's Avatar
beatiful engine setup....very clean...whats your whp goal....?
Old Sep 1, 2005 | 09:02 AM
MR.M's Avatar
Default Re: Some updates (Black_JDM Type R)
We want to get 850whp+
Old Sep 1, 2005 | 10:06 AM
Axel Foley's Avatar
wow, thats one of the best setups i've seen in a 240 yet. no tomei or jun stroker kit? what color green is that. im looking to paint my DA army/dark olive drab green, but haven't fund a paint code yet.
