some turbo questions
Old Sep 11, 2002 | 07:41 PM
specie's Avatar
Default some turbo questions
Well, I had a greddy (15g) turbo-ls in my Crx. Then I sold it and went all motor ls/vtec. I just recently bought a '95 GSR w/o drivetrain. I was thinking about going ls turbo on this car, I don't think all motor could move this heavy car.
I haven't been reading this forum for a while. I need some experiences you guys have. I don't have much money so I need the most cost effective parts that is reliable with daily use. I know that sounds stupid, but at least closest to being reliable. I usually don't drive my car too hard, only on few ocassions.
What's good out there?
I know people like Garret turbos compared to Turbonetics. (what's a good size/trim; I'm going to work on stock ls motor and maybe 8-10psi).
I'm probably go with a Tial wastegate (I'm new to this since the Greddy uses an internal wastegate.)
I had a spearco intercooler and it was good to me. What are other good choices? Would a Starion IC work okay?
I had a MSD 6btm, would I need some sort of ignition for 8-10psi?
I'm planning on running DSM 440 injectors, maybe on one of those SMC (Zip22 on clubsi.com). If not that, would a Hondata 2b be adequate? Does anyone have experience with these injectors?
I'm on a budget. Would it be cheaper to get a complete kit or just look around for parts to piece together a kit?
Could you guys tell me what you guys have good experience with and what to steer away from? Thanks alot for all inputs.
Old Sep 11, 2002 | 09:49 PM
reXem's Avatar
Default Re: some turbo questions (specie)
If you are looking for budget turbo the only way is homemade. Get a used turbo of a junkyard car, get it rebuilt if it needs and work up from there. Scour classifieds for used parts and ask here for whether the parts will work together. I am currently running a homemade ZC turbo and I love it. For the turbo setup only about 2000 (canadian) has been spent. I am current runing a td05h-18G from an eclipse, a homemade manifold, TurboXS Type-S BOV, no IC, and the only fuel mangement I am using is a B&M FPR. Spark plugs show no pitting (detonation). My best time was 14.9 with a 2.5 60' 30+ degree celcuis (really hot) and the time correct (supposedly) for this track is .4 (so technically a 14.5) and this was at almost 96mph. These are on crappy stock tires (from my previous '00 civic)
Old Sep 12, 2002 | 11:06 AM
specie's Avatar
Default Re: some turbo questions (reXem)
Thanks.
I think I'd like to go a little bigger than the junkyard turbo (like a T3/T4). I've seen a lot of people with D-series manifold (made from HF) but I haven't seen much about homemade B-series manifold (well at least ones that are very affordable).
I would like to keep the AC, that's the reason I chose the Integra.
I've seen a few b16a putting out good power, there is a couple of turbo itrs that aren't responding too well, I haven't seen any turbo gsr around here, and one ls turbo? Which stock motor handles boost well and make good power. I know the ls has the largest displacement and it has the lowest compression ratio. Is there still the debate over vtec or non-vtec for boosting?
Thanks.
What components do you guys think work together well?
Old Sep 12, 2002 | 11:16 AM
reXem's Avatar
The eclipse turbos are fairly large and are good for some decent power, I think I saw somewhere someone was getting 400whp from the 16G. As for manifold, I am not sure if there is an easy homemade for b-series....
greygoose
Nov 12, 2008 10:28 PM
SPOONup
May 3, 2005 08:46 PM
JustinL
Oct 9, 2004 04:34 PM
Hondata1337
Jun 3, 2004 10:46 PM
hydroflip
Jun 30, 2001 12:03 PM
