sohcT new dyno numbers
Old May 8, 2008 | 05:19 PM
sohcT's Avatar
Default sohcT new dyno numbers
Had my car tuned on Tuesday. It feels faster then ever, even though the numbers are a bit lower. Tuned at 18psi on Sunoco 94 pump gas. Thanks to Corey at Slowmotion Motorsports.
Specs:
1997 EJ6 Honda Civic LX SOHC-T
D16Y7 sohc non-vtec, decked, bored, blueprinted and balanced, custom Wiseco pistons (high-temp coated), Eagle H beam rods, ARP head studs and rod bolts, Balanced, polished knife-edged crank, Cometic head gasket, stock d16y7 cylinder head, Edelbrock Performer X intake manifold, Custom 3" exhaust, Catco cat, RMS Fab Custom exhaust manifold & 3" downpipe, Tial 38mm Wastegate, ApexI N1 muffler, ApexI AX53 B60 P18 ball bearing turbo, ApexI GT front mount intercooler, ApexI blow off valve, ACT 6 puck clutch, GM 3 bar map, GM Boost solenoid, P06 ECU, Hondata S300, Precision 525cc injectors, AEM fuel rail, Aeromotive fuel pressure regulator, Walbro 255lph fuel pump, NGK plugs
Modified by sohcT at 4:46 PM 5/16/2008
Old May 8, 2008 | 05:21 PM
Autoworks's Avatar
Default Re: sohcT new dyno numbers (sohcT)
very nice
whp and tq hanging right in there together
Old May 8, 2008 | 06:49 PM
PhantomX's Avatar
Default Re: sohcT new dyno numbers (Autoworks)
Loooookin Goooood
Old May 9, 2008 | 01:17 PM
sohcT's Avatar
Default Re: sohcT new dyno numbers (PhantomX)
Thank you. I'm looking forward to getting her to the track!
Old May 9, 2008 | 06:30 PM
perlmeister8's Avatar
Looks good as always, love CBM and single boost
Old May 9, 2008 | 07:00 PM
zex_cool's Avatar
mani looks "different"......i like.
why only rev to 6.6K ?
Old May 9, 2008 | 10:18 PM
joe111599's Avatar
very nice car bro...
Old May 10, 2008 | 05:51 AM
sohcT's Avatar
Default Re: sohcT new dyno numbers (perlmeister8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perlmeister8 &raquo;</TD></TR><TR><TD CLASS="quote">Looks good as always, love CBM and single boost </TD></TR></TABLE>
I wouldn't have it any other way!! How's your ride?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zex_cool &raquo;</TD></TR><TR><TD CLASS="quote">mani looks "different"......i like. why only rev to 6.6K ? </TD></TR></TABLE>
The head is completly stock for the time being and it wasn't making anymore power after 6600.
Old May 10, 2008 | 07:33 AM
93CX's Avatar
Looks good for such a small snail
Old May 10, 2008 | 11:37 AM
dispocrx's Avatar
not bad numbers, but Why did you go with a non-vtec setup? seems like 18psi would get you alot more power than that...but im not real sure of your turbo specs either...Good Job!
Old May 10, 2008 | 08:14 PM
95civhb's Avatar
Default Re: (dispocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dispocrx &raquo;</TD></TR><TR><TD CLASS="quote">Why did you go with a non-vtec setup? </TD></TR></TABLE>
Old May 11, 2008 | 09:53 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcT &raquo;</TD></TR><TR><TD CLASS="quote">
I wouldn't have it any other way!! How's your ride?</TD></TR></TABLE>
It is up and running on E85 and tuned up. Had some ignition break up issues that ended up blowing my headgasket, so that will be replaced here soon and I will get to the track for some times
Old May 11, 2008 | 04:49 PM
sohcT's Avatar
Default Re: (95civhb)
I kinda like building an underdog and doing something a little differently. I am eventually going to do a y8 head and a larger turbo but this is nice for now.
Old May 11, 2008 | 05:50 PM
91tegrals's Avatar
nice set up im hoping for simalier results when im done with my z6 t
Old May 15, 2008 | 01:08 PM
Smokinsax's Avatar
The Boot
Default Re: (sohcT)
I am eventually going to do a y8 head and a larger turbo but this is nice for now.</TD></TR></TABLE>what kind of mods to the head do you want to go with?
Old May 15, 2008 | 01:37 PM
Teglove2's Avatar
Thanks for props on the "custom exhaust manifold" Danny. Sorry about those kids at BK they didnt know the situation between us. I built that manifold.
Old May 17, 2008 | 07:11 AM
sohcT's Avatar
Default Re: (Smokinsax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">what kind of mods to the head do you want to go with?</TD></TR></TABLE>
I'd like to fully build a y8 head; valves, springs, retainers, cam, port and polish. I could use some suggestions on a cam. Have any?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for props on the "custom exhaust manifold" Danny. Sorry about those kids at BK they didnt know the situation between us. I built that manifold.</TD></TR></TABLE>
It's cool. It's a RMS fab manifold, downpipe and dump tube.
Old May 17, 2008 | 08:23 AM
.dave's Avatar
i HAS questions ?
Default Re: (sohcT)
More boost! It looks like it wants to keep going.
Props on a clean and simple setup.
Old May 17, 2008 | 09:53 AM
k_civic's Avatar
Default Re: (.dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .dave &raquo;</TD></TR><TR><TD CLASS="quote">More boost! It looks like it wants to keep going.
Props on a clean and simple setup. </TD></TR></TABLE>
agree x2
Old May 17, 2008 | 09:59 AM
H.A.R.T B18C1EG6's Avatar
Default Re: (k_civic)
clean bay nice numbers
Old May 17, 2008 | 04:45 PM
Radyjr's Avatar
loving the single cam boosted, but the silicone hose that goes to the t.b looks a little bit off or too many clamps holding it.... Keep up the good work......
aleks77
Jan 26, 2010 06:23 PM
H22NOSACC
Dec 17, 2008 04:12 PM
vwtuner
Apr 12, 2007 03:13 PM
twilson
Apr 9, 2007 07:39 PM
sohcT
Jul 27, 2004 09:40 PM
