SOHC VTEC HEAD LIFTING....
Old Dec 17, 2004 | 11:49 AM
  #26
platinum00's Avatar
Default Re: SOHC VTEC HEAD LIFTING.... (Hella_JDM)
i had the same problem as yellow turbo.
the markings on mine were from movement as well..
platinum.
Old Dec 17, 2004 | 11:51 AM
  #27
beerbongskickass's Avatar
Default Re: SOHC VTEC HEAD LIFTING.... (platinum00)
I will go take some pictures of my head gasket if I can find it. I'm not sure what "markings from movement" look like though lol.
Old Dec 17, 2004 | 11:57 AM
  #28
yellowturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">i know my sleeves dont move , i have a closed deck aebs block , and i still have this problem , but like ive said . i think its my warped head lol.</TD></TR></TABLE>
yeah I dont think that the problem is your block... a wrapped head doesnt help that much loll
Old Dec 17, 2004 | 11:59 AM
  #29
ELSpool's Avatar
Default Re: SOHC VTEC HEAD LIFTING.... (beerbongskickass)
Since I've been through a few, I can tell you. When you pop a HG do to poor tune or det, you will see only a small spot where the gasket blows out. It my other cases, a big portion on the gasket was lightly scraped away, making me think the sleeves were slight shifting, or the block was twisting. Almost 25% of the cylinder circle in the HG was roughed up, but not chunks were taken out..
Old Dec 17, 2004 | 12:09 PM
  #30
RyanEJ8's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">
thats what im trying to explain... : the sleeves are walking under boost or high load. Damn its not easy for a french guy to explain all that stuff loll !! </TD></TR></TABLE>
In that quote, Jeff is speaking about the actual D Series aluminum block casting not being torsionally as strong as the B Series. Sleeving the block is not going to help solve this issue. This is also only a theory of his anyways. No acutal proof of this yet.
Old Dec 17, 2004 | 12:13 PM
  #31
Default Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
In that quote, Jeff is speaking about the actual D Series aluminum block casting not being torsionally as strong as the B Series. Sleeving the block is not going to help solve this issue. This is also only a theory of his anyways. No acutal proof of this yet.</TD></TR></TABLE>
ok ok .... your the boss. I think that you know what I mean...
Old Dec 17, 2004 | 12:59 PM
  #32
RyanEJ8's Avatar
ok ok .... your the boss. I think that you know what I mean...</TD></TR></TABLE>
I'm not the boss. Just trying to get some information out here, so we're all on the same page. Don't take it personally yellowturbo.
BTW, have you at one point had headgasket issues, either before or after sleeving?
Old Dec 17, 2004 | 01:06 PM
  #33
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">I will go take some pictures of my head gasket if I can find it. I'm not sure what "markings from movement" look like though lol.</TD></TR></TABLE>
i have seen several blown gaskets, some look different then others.
what im talking about, is scatches like something moved. dont know if it was the block or the head. but something moved under load..
platinum.
Old Dec 17, 2004 | 03:48 PM
  #34
2muchPSI's Avatar
Default Re: SOHC VTEC HEAD LIFTING.... (CivicEJ1)
mine lifted on 22psi
Old Dec 17, 2004 | 09:10 PM
  #35
green91's Avatar
so would a blockgaurd be a better security measure then ARPs?
Old Dec 17, 2004 | 09:21 PM
  #36
ATS*Mark's Avatar
OG triple OG
Default Re: (green91)
my head wasnt warped at all today when i took it in , very wierd , it was resurfaced anyway to get a clean surface for the headgasket. but i found that so wierd....
UniqueX707
Aug 26, 2012 11:52 AM
perosis
Apr 7, 2007 02:31 PM
JDMvtecDRAGSTA
Apr 22, 2002 07:54 PM
