Sohc Turbo Help?
Subscribe
Dec 1, 2004 | 12:33 PM
i have a d16z6 w/ about 140k on the motor. It doesnt run very strong, so i plan to buy a d15b from a local shop. i have a turbonetics t3/t4, turbonetics wastegate, spearco IC, drag piping, 3" downpipe, vortech BOV and a vortech 12:1 Fmu. I need sum help on what i else i should run on my d15b. wat kinda fuel injectors? what kinda EMS? etc.? let me kno wat u think i should do in order to have a fast street/strip setup...maybe have around 260 hp at 9psi. thanks.
Reply 0
Dec 1, 2004 | 12:45 PM
Re: Sohc Turbo Help? (JdmLsPwr425)
260 @9psi on a d15 may be a stretch. but you should definetly find an uberdata tuner and if not then buy hondata and find a good hondata tuner. you can sell your fmu because you wont need that if u are tuning with uberdata or hondata. for your goals you could get 440 injectors or possibly save some cash and get dsm 450's. id go 550's for some space down the road. new fuel pump, also if u get Peak and hold injectors you will need a resistor box. you can find an oem honda one for like $15. other than that just research uberdata and hondata to find out exactly what you wanna do and what all you would need for each. new ecu, conversion harness, etc.
Reply 0
Subscribe
