SOHC Turbo Cams?
Old Jan 28, 2003 | 06:13 AM
P18AJ79's Avatar
Default SOHC Turbo Cams?
I know this topic has been adressed but i havent really herd anything on this that says these are good or these are bad so I have been debating between Crane, CROWER, SKUNK2 and a few others and im totaly lost on which one to purchase for my Y8 head? any help/ experiences would be great.
Thanks
Justin
[Modified by MAKURAGI, 3:14 PM 1/28/2003]
[Modified by MAKURAGI, 3:40 PM 1/28/2003]
Old Jan 28, 2003 | 06:52 AM
ladysman's Avatar
Default Re: SOHC Turbo Cams? (MAKURAGI)
I would be curious as well on this subject.
Old Jan 28, 2003 | 07:25 AM
P18AJ79's Avatar
Default Re: SOHC Turbo Cams? (ladysman)
Bump
Old Jan 28, 2003 | 08:12 AM
boostedel's Avatar
I went with crower.
Old Jan 28, 2003 | 08:26 AM
P18AJ79's Avatar
Default Re: SOHC Turbo Cams? (boostedel)
do you like them? is the idle lumpy and which stage did you go with? and did it make a difrence in power curve?
Old Jan 28, 2003 | 12:37 PM
boostedel's Avatar
Default Re: SOHC Turbo Cams? (P18AJ79)
I'll let you know once I get the car running. Just finishing up putting together my new turbo setup.
Old Jan 28, 2003 | 12:40 PM
evolve's Avatar
Turbo cams shouldn't be lumpy. Turbo engines don't benefit as much from overlap. Usually the duration is only a slight different from stock, but the lift is much higher.
Old Jan 28, 2003 | 01:40 PM
boosted hybrid's Avatar
I am going with the Crower turbo cam for my d-series project. I have taken a look at all the turbo d cams that are available, and for the money and specs on paper it seems to be the best choice. Who knows how it is going to preform though. I might get a slight boost in performance from the cam running 11:1 compression, over lower compression set-ups.
nlcivicboost
Mar 2, 2005 12:31 PM
93acclude
Jun 16, 2004 11:15 AM
slowww b18b1
Apr 23, 2004 12:24 PM
PaChiLa Leader
Nov 17, 2001 02:36 PM
