SOHC torque specs
Old Sep 3, 2005 | 08:59 PM
SOHCboost's Avatar
Default SOHC torque specs
i got sum ARp head studs wat should i torque 2?
Old Sep 3, 2005 | 09:01 PM
93supercoupe's Avatar
Default Re: SOHC torque specs (SOHCboost)
Also, can I use my GSR headstuds in my y8?
Old Sep 3, 2005 | 09:18 PM
tilt's Avatar
60ft/lb with moly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCboost &raquo;</TD></TR><TR><TD CLASS="quote">i got sum ARp head studs wat should i torque 2? </TD></TR></TABLE>
Old Sep 3, 2005 | 10:41 PM
EnzoSpeed's Avatar
Default Re: SOHC torque specs (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">Also, can I use my GSR headstuds in my y8?</TD></TR></TABLE>
You wish.
Although I guess you could whittle then down to 10mm and they'd fit.
Old Sep 3, 2005 | 10:53 PM
JFK78's Avatar
I personally torque them to 75ft/lbs w/ARP moly lube. Everybody seems to have their own preference though.
Do you mind giving details on your R.I.P. setup that went 12.1 @ 112?
Old Sep 3, 2005 | 11:22 PM
nerdsports's Avatar
Default Re: SOHC torque specs (JFK78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 &raquo;</TD></TR><TR><TD CLASS="quote">Do you mind giving details on your R.I.P. setup that went 12.1 @ 112? </TD></TR></TABLE>
id like to know as well.
Old Sep 3, 2005 | 11:40 PM
SOHCboost's Avatar
haha..... stock z6 12 lbs launch at 7200 rpm on big slicks..
Old Sep 3, 2005 | 11:42 PM
SOHCboost's Avatar
Default Re: (SOHCboost)
by the way how do like the zex cam in ur car... did u upgrade valve terian?
Old Sep 4, 2005 | 12:36 PM
JFK78's Avatar
I really like the ZEX cam. Better midrange and top-end. I run stock valvetrain and rev to 7500rpm.
Your setup: What size turbo, injectors, slicks? How did it blow?
Old Sep 5, 2005 | 05:29 PM
1995Civic's Avatar
Default Re: (JFK78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFK78 &raquo;</TD></TR><TR><TD CLASS="quote">I really like the ZEX cam. Better midrange and top-end. I run stock valvetrain and rev to 7500rpm.
The Zex 59300 cam is great, especially for boost applications. I wouldnt recommend running stock valvetrain with it though, because of the higher lift could cause lifting of the valves. When upgrading, i would definitely go with the Crower Springs/Ti-retainers
Old Sep 5, 2005 | 06:52 PM
AMkrew_1's Avatar
Default Re: (1995Civic)
duh. the cam is meant to lift the valves...
you probably meant "without the valvespring upgrade, the higher ramprate, and lift on the zex cam could induce valve-float at higher rpm"
Old Sep 6, 2005 | 06:28 PM
1995Civic's Avatar
Default Re: (AMkrew_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMkrew_1 &raquo;</TD></TR><TR><TD CLASS="quote"> duh. the cam is meant to lift the valves...
you probably meant "without the valvespring upgrade, the higher ramprate, and lift on the zex cam could induce valve-float at higher rpm"</TD></TR></TABLE>
true that homie! my bad for the false statement. Was a long night
Old Sep 6, 2005 | 06:33 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1995Civic &raquo;</TD></TR><TR><TD CLASS="quote">The Zex 59300 cam is great, especially for boost applications. I wouldnt recommend running stock valvetrain with it though, because of the higher lift could cause lifting of the valves. When upgrading, i would definitely go with the Crower Springs/Ti-retainers </TD></TR></TABLE>
the zex valespring upgrade will do just fine
IA95civicDX
10
Jun 18, 2007 08:51 AM
lx-sedan
Jun 24, 2006 05:31 AM
DC2 Mang
11
May 11, 2006 05:29 AM
92ehatch
Oct 7, 2005 04:19 PM
RyanEJ8
Mar 24, 2005 06:19 PM
