sohc sc belt problem
Old Feb 20, 2008 | 07:32 PM
b18 hatch mike's Avatar
Default sohc sc belt problem
my buddy just bought the car and the belt broke but i noticed th belt was hitting the bottom of the timing cover were the water pump is jw were we can ge a belt
i found some on jr but i want to know if like autp zone had one
HELP
Old Feb 21, 2008 | 05:36 AM
creechrr's Avatar
Default Re: sohc sc belt problem (b18 hatch mike)
If I remember correctly, the belt for the SOHC kit needs to be 44". Take the old belt to a parts shop and have it measured.
Old Feb 21, 2008 | 12:41 PM
Default Re: sohc sc belt problem (creechrr)
ok so what about the belt rubbing the timing cover
Old Feb 21, 2008 | 03:11 PM
inspyral's Avatar
I remember rmcdaniels saying something about how the alternator bracket in the early JRSC kits were a little off and newer kits including shims to fix it. You might want to look into shimming it out so that it lines up better and doesn't rub the timing cover.
Old Feb 21, 2008 | 05:00 PM
Legion's Avatar
* B A N N E D *
Default Re: (inspyral)
Mine only rubbed slightly until the belt notched into the plastic and self-clearanced itself. Problem solved. If it rubs more than a little, you probably need to tighten the belt more anyway.
Also, you can buy the belts direct from Jackson Racing online. That's where I used to buy mine and they had super fast shipping too. Usually took 2-3 days to get my stuff (in SoCal).
Old Feb 21, 2008 | 05:10 PM
Default Re: (Legion)
ok. well i can look up and see the water pump sprocket cause it rubbed all the way through the cover cant tell if it is hitting the sprocket yet
Old Feb 21, 2008 | 11:23 PM
Legion's Avatar
* B A N N E D *
Default Re: (b18 hatch mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">ok. well i can look up and see the water pump sprocket cause it rubbed all the way through the cover cant tell if it is hitting the sprocket yet </TD></TR></TABLE>
Damn, that's bad. Are you sure you installed the JR lower alt. bracket?
Old Feb 22, 2008 | 08:17 AM
like d he just bought it with the sc on it and i was looking at it and i know 0 about sc lol
bump
Old Feb 22, 2008 | 05:44 PM
Legion's Avatar
* B A N N E D *
^^ I don't know what you just said...
But anyway, this is a simple problem to resolve. Step 1 is to put a new belt on, and see if everything is in alignment.
civic=goodgasmileage
Honda Civic (2001 - 2005)
Oct 11, 2008 09:17 AM
MassCivicMan987
Jun 28, 2007 11:48 AM
MassCivicMan987
Jul 3, 2006 04:25 PM
crx_88_si
Jun 30, 2005 09:02 AM
