sohc (notch the sleeves with eagle rods??)
do you have to notch the sleeves to run eagle h beam rods in a sohc? searched but with no luck... pics would be helpful thanks....
http://www.theoldone.com look under d-series builds in the articles section it gives pics and details on nothcing the block
well in my bros motor we just got built its a d16y8 we used Eagle H beams had to notch the block and notch the cradle if you didnt notch the cradle the bolts on the rods would hit when it came down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sp00nek9 »</TD></TR><TR><TD CLASS="quote">are there any other companies that make an i beam rod besides crower?</TD></TR></TABLE>
well there is pauter and carrillo but those cost 3 times as much as eagles, notching the block is very easy and can be done in a 1/2 hour
brusk13
Jun 8, 2005 08:36 PM
