So, I changed my plugs.....
Old Dec 19, 2003 | 12:08 PM
1.8t's Avatar
Default So, I changed my plugs.....
I went from OEM plugs to some BKR7E-11s and gapped them down to .028. The car def. doesn't idle well with them, seems like it has some trouble igniting the mixture. Now, w/ oem plugs the car ran and idled great. So you think I should just re-gap these BKRs to say .032 or run my OEM plugs again? I am only running a max of 6.03psi according to hondata on my stock b18b. When I pulled the OEM plugs, they looked perfect.
Old Dec 19, 2003 | 12:11 PM
ELSpool's Avatar
When you drop heat ranges, the spark plug will not retain enough heat to burn off exccess fuel under idle, and will tend to foul more often then the standard heat range plug. Try leaning out your fuel table at idle more.
Old Dec 19, 2003 | 12:41 PM
1.8t's Avatar
Default Re: (ELSpool)
Will do...thanks for the help.
Old Dec 19, 2003 | 01:04 PM
InTeGrA B18b1's Avatar
Default Re: (1.8t)
i run the bkr7e at .030 on my ls turbo running 8-11 psi.
Old Dec 19, 2003 | 03:27 PM
TurboDANDEE's Avatar
i run 9 heat range and my mixture on idle is shitty on .28 gap, haha.
Bobby_Budds
Dec 19, 2012 05:32 AM
Ash J. Williams
Jan 28, 2011 02:16 PM
Lewsears
Mar 20, 2010 09:25 AM
SuM Honda
Jan 1, 2010 07:29 PM
planoguy36
Jun 7, 2006 07:29 AM
