Snap Intake valve spring,what cause this?
Old Aug 7, 2014 | 09:40 AM
carlos8's Avatar
Default Snap Intake valve spring,what cause this?
Hi, Recently in a third pull my car fall in his face, when I press the clutch barely made idle. Pull it to my house and made a compression test 0 cyl #4.
Remove the cover to find one valve spring in 5 parts two the outer 3 the inner and the other intake spring the outer broke in two. Take the head out and the valve barely touch the piston (she was bend and stuck in close position).
I bought the two springs. But before assembly all I want to know what can cause this kind of failure?
Any help will be appreciated.
https://honda-tech.com/attachment.ph...1&d=1407429626
Old Aug 7, 2014 | 09:44 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Snap Intake valve spring,what cause this?
Setup would help... cams, springs, parts list, rpm range, power level, etc..
Old Aug 7, 2014 | 10:42 AM
carlos8's Avatar
389whp @ 17psi 8,500RPM
GSR cams
B16a head
Ls block 9.0:1 SRP, Eagle Rods
Rocket SL dual springs, S/S retainers from hypersonicAuto
I swapped my Type R cams for the GSR's recently and valve lash was made. Also replaced the rocket arms but in the exhaust side.
Old Aug 7, 2014 | 11:35 AM
Muckman's Avatar
Moderator in Chief
What are reving to?
Old Aug 7, 2014 | 12:04 PM
carlos8's Avatar
8,500 RPM
Old Aug 7, 2014 | 02:59 PM
wantboost's Avatar
Who is Mr Robot?
I've heard a lot of Rockets springs have been breaking (not like all at once but I've seen a few topics regularly about sets breaking). I have an earlier set that snapped an inner on a built all motor b16 during break in.
IIRC it's always the inners that break with some of the earlier stuff, not sure why though. You need to contact him on here.
State.of.Prime
Oct 17, 2010 01:43 PM
avotegra
Dec 3, 2008 12:35 PM
daidilus
25
Aug 18, 2006 08:21 AM
jwaked
Oct 17, 2003 01:13 PM
Ovl55rag
Oct 17, 2002 09:35 AM
