smoking off throttle?
Old Feb 26, 2007 | 06:57 AM
chris@inlinepro's Avatar
Default smoking off throttle?
hey guys, i have a quick question. I have a 2000 S2000 w/ an inlinePRO turbo kit. The car runs amazing, i just recently put down 380whp @ 9lbs with a slipping clutch. Like i said all is fine, except the car smokes from the exhaust off throttle...when i first got tuned it only did it some times but lately its more often. Its not a white smoke, but looks like oil smoke and only occurs off throttle. In boost or on the gas there is no smoke but once i let off it starts smoking. Some answers ive gotten seem to be pointed towards a bad turbo seal. Its a GT35R and would be covered under warrenty but before i take the time to pull the turbo off and sent away i want to make sure that is what it is. Thanks guys
Old Feb 26, 2007 | 10:31 AM
631 Teggy's Avatar
Default Re: smoking off throttle? (2k_SI)
Is it when you are coasting in gear? Like decelerating? If so, I have the same problem. Probably turbo seal or valve seals.
Old Feb 26, 2007 | 10:43 AM
SOHC_MShue's Avatar
Default Re: smoking off throttle? (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">Is it when you are coasting in gear? Like decelerating? If so, I have the same problem. Probably turbo seal or valve seals.</TD></TR></TABLE>
word
tealegg's Avatar
x2
Old Feb 26, 2007 | 11:25 AM
Decel, coasting, anything as long as i am off throttle it smokes. So you think its the turbo seals?
Old Feb 26, 2007 | 06:15 PM
TTT
Old Feb 27, 2007 | 03:24 PM
631 Teggy's Avatar
Default Re: (2k_SI)
Even at idle?
Old Feb 27, 2007 | 05:17 PM
MidShipCivic's Avatar
Turbo Seals ( majestic bluish smoke with off throttle decel and idle) .
Old Feb 28, 2007 | 07:49 AM
Default Re: (MidShipCivic)
yup, that pretty much describes it. off throttle and at idle. So i guess Midship from my explanation you can say its the turbo seals?
Old Feb 28, 2007 | 05:30 PM
Default Re: (2k_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k_SI &raquo;</TD></TR><TR><TD CLASS="quote">yup, that pretty much describes it. off throttle and at idle. So i guess Midship from my explanation you can say its the turbo seals? </TD></TR></TABLE>
Yeah pull off your turbo charge pipe just at every tube to coupler and see if there is oil plastered everwhere, I doubt an S2000 has valve seal problems.
Old Feb 28, 2007 | 06:28 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah pull off your turbo charge pipe just at every tube to coupler and see if there is oil plastered everwhere, I doubt an S2000 has valve seal problems.</TD></TR></TABLE>
My turbo seals only leak on the exhaust side. So I have no oil in my charge pipes. That method is good but sometimes only the hot side leaks. It only takes a tiny drop to make a cloud of smoke.
Old Feb 28, 2007 | 07:29 PM
Default Re: (631 Teggy)
My turbo seals only leak on the exhaust side. So I have no oil in my charge pipes. That method is good but sometimes only the hot side leaks. It only takes a tiny drop to make a cloud of smoke.</TD></TR></TABLE>
Good point.
Old Mar 1, 2007 | 09:06 AM
kulrevon's Avatar
In a non turbo car I would say valve seals in a second. But not sure.
Old Mar 1, 2007 | 12:28 PM
thanks midship, like i said the turbo is under warrenty so ill send it back soon enough. Again, thanks
tyler8469
Jun 23, 2016 07:47 AM
k20powered
May 1, 2010 07:07 AM
jaymes2030
Jan 17, 2004 08:20 PM
Evil DOHC
Jun 23, 2003 12:10 PM
fsp31
Dec 12, 2002 11:11 AM
