Slicks...beaten to death..
Old Aug 2, 2003 | 05:46 PM
Blown90hatcH's Avatar
Default Slicks...beaten to death..
My eyes hurt from reading all the slick threads, but I could not muster up an answer. Which of these two different slicks should I get. Approx 450-520whp when done. I have to get the 15" slick to clear my ITR brakes. Stock fenders.
9.2/24.0-15 M&H or 8.5/24.5-15
Thanks, Jason
Old Aug 2, 2003 | 07:24 PM
Foozball26's Avatar
Default Re: Slicks...beaten to death.. (Blown90hatcH)
what tranny are you running
Im tempted to say the 24.5 since it will give you more sidewall especially with that 15" rim. But the 24" is wider.
My vote is for the 24.5" x 8.5
Modified by Foozball26 at 11:37 PM 8/2/2003
Old Aug 2, 2003 | 07:48 PM
meanteg's Avatar
New User
Default Re: Slicks...beaten to death.. (Foozball26)
I'd say 9.2 .
Old Aug 3, 2003 | 04:13 AM
Oh yeah....GSR trans.
Old Aug 3, 2003 | 06:51 AM
hybrid901's Avatar
What is your readline?
Old Aug 3, 2003 | 07:59 AM
Default Re: Slicks...beaten to death.. (hybrid901)
8500 was where the power/tq was leveling off. 9000 if I had to.
Old Aug 3, 2003 | 10:34 AM
24.5 fit under the stock fenders as well I think.
Old Aug 3, 2003 | 01:55 PM
Anyone have the average trap speeds for this setup and 10.90ish
Thanks
Old Aug 3, 2003 | 05:16 PM
turbotypeR@SPEC's Avatar
25 Year Member
i had major traction problems with the 24x9.2
Old Aug 3, 2003 | 05:43 PM
Default Re: Slicks...beaten to death.. (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">i had major traction problems with the 24x9.2</TD></TR></TABLE>
Did you go with the 24.5? I am calculating my 4th gear MPH and I think the 24s are going to come up short.
Old Aug 3, 2003 | 08:24 PM
saso
Guest
Posts: n/a
why dont you try the 26' can they fit, prob not. Go with the largest that can fit bc 500hp is plenty. Im sure the 24-24.5 will get you in the 10's. Oops I would try the 9.2 if you are in the 500 range. Wider for more traction ,prob if you are making gobs of tq.
Old Aug 4, 2003 | 04:05 AM
25 Year Member
i had 24" and they didn't work well because they didn't have enough sidewall.i went 128mph hitting the rev limiter in 4th.now i have 26" goodyears and the work much better.i am going through the traps in the around 7000rpm now.
Old Aug 4, 2003 | 07:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR &raquo;</TD></TR><TR><TD CLASS="quote">i had 24" and they didn't work well because they didn't have enough sidewall.i went 128mph hitting the rev limiter in 4th.now i have 26" goodyears and the work much better.i am going through the traps in the around 7000rpm now. </TD></TR></TABLE>
Can you fit the 26" slicks under your stock fenders? If not, I will go with the 24.5 slicks.
Thanks Jason
Old Aug 4, 2003 | 05:56 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks Jason</TD></TR></TABLE>
yes.i had to raise the front 1" and trim the inner lip of the front bumper and remove the plastic fender well.
Old Aug 4, 2003 | 06:24 PM
Cool. Thanks man.
GSR4U2NV
Apr 28, 2006 01:21 PM
Sleepy_Red_hatch
Oct 14, 2005 09:54 AM
b18c195
Jun 22, 2004 01:29 PM
GSRwBOOST
Acura TL, RL & ZDX
Aug 18, 2003 08:57 PM
bottlefedintegra
Jul 7, 2003 09:33 PM
