... to sleeve or not to sleeve... that is the question
current setup : see sig
goals :
- 22-23psi
- 350-400whp
can i get there with just pistons/rods and tuning?... also, what are everyone's recommendations for achieving my goals?... lemme know... thanks in advance...
goals :
- 22-23psi
- 350-400whp
To search or not to search that is the question.. Plenty of info on it..
... next time dont both replying... i already did a search... now did you not answer because you didnt know... or because you were too lazy to help... i doubt you were too lazy cuz you wasted you time so say "search"... so i am gonna have to go with the fact that........ whatever....slowb16 : thanks for the reply...
up to you...got the money, do it!
it will give you peice of mind and youll know you wont crack a sleeve
BUT the stock sleeves CAN handle your power goals no problem. (good tuning)
Its up to you really.
fyi, someone made like 608 WHP on stock sleeves
[Modified by SiRkid, 5:22 AM 10/22/2002]
It's not a pressure dependant thing. The general concensus is typically 350whp is "safe" on stock sleeves. More is <U>possible</U> with a higher degree of tuning. Sleeves are usually damaged by detonation, not horsepower alone.
Smarter than you
once u sleeve a block, it can be your block forever. keep that in mind when looking at the price for a new core if u happen to crack a sleeve.
can it be done on stock sleeves? yes, it obviously been proven. but should u run it on stock sleeves? yes or no depends if u want to take chances.
<will be sleeving when he builds
Actually, my GE block is already sitting in my living room
My hp goals were right on the edge of reliability giving the tuning available to me, so I erred on the side of caution.
killer_siller
Mar 8, 2009 10:12 AM
integraboosted
Nov 13, 2005 06:11 PM
