skunk 2 throttle body & TPS issue
Old Mar 12, 2014 | 09:38 AM
turbonetics3597's Avatar
Default skunk 2 throttle body & TPS issue
so its a proseries 70mm throttle body when trying to install the tps into the notch on the throttle body the way it fits is so offset that the bolts dont line up so i rotate the tps to where the bolts will line up and cannot get the tps to hold a set voltage it bounces around .02 to .04 off i have tried 2 tps in it with no success im wondering if anyone knows if its like that on theirs. im beginning to think it is a defective one or maybe it can be rotated if i disassemble it. i found some pics of a stock one being done and the bolts line up with the notch
Old Mar 13, 2014 | 05:08 AM
ls joker's Avatar
Loved
Default Re: skunk 2 throttle body & TPS issue
have you played with the throttle stop
Old Mar 14, 2014 | 02:20 AM
yeah ive messed with every screw on it to try and getting to hold a voltage the only other thing i can think is i had to cut and weld the bracket for the throttle cable so it would clear the hood without rubbing but im at a loss i might just buy another see what it is like
Old Mar 14, 2014 | 03:51 AM
MRGRIM's Avatar
R.I.P. Mark
try with no cable connected to disregard the cable as an issue
are the other sensors getting voltage movement as well ...
Old Mar 14, 2014 | 05:31 AM
Muckman's Avatar
Moderator in Chief
Lets see a picture.
Old Sep 6, 2015 | 12:40 PM
sorry no pic, no cable doesnt help but its almost steady now it bounces from .25 to .27 which isnt to big of deal. but my primary suspect is throttle body it almost sticks a little bit when completely shut think it might not have been machined perfect.
Old Sep 6, 2015 | 02:11 PM
NotARaCist's Avatar
I never narc'd on nobody!
<p>Wow, year and a half later. &nbsp;That's some dedication.</p><p>Your problem is a shitty throttle body. &nbsp;Junk2.</p>
Old Sep 6, 2015 | 02:24 PM
yeah unfortunately if i was rich or didnt cut the tps off the stock one id buy a new one. but in due time
Old Sep 6, 2015 | 02:38 PM
NotARaCist's Avatar
<p>There are these awesome things called junk yards, where you can get used parts for stupidly cheap. &nbsp;Try it.</p>
Old Sep 6, 2015 | 04:21 PM
wantboost's Avatar
Who is Mr Robot?
They are free technically. The "rule" at junkyards is if it fits in your pocket then it's free lol.
Old Sep 6, 2015 | 09:21 PM
wunfstgsr's Avatar
Loved
Community Favorite
lol yup called pick a part where im from haha
Old Sep 7, 2015 | 03:11 AM
wantboost's Avatar
Who is Mr Robot?
Same here... And I'm definitely overdue for a visit.
Old Sep 7, 2015 | 05:02 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Around here most yards crushed everything 1995 and older...
Definitely starting to feel old, LoL!
Old Sep 7, 2015 | 10:32 AM
m4xwellmurd3r's Avatar
If it can fit on your person its free.
Got lots of harnesses and throttle/clutch cables lol
Old Sep 7, 2015 | 07:43 PM
Id be taking th hole the throttle body to fix it I bought another tps same result but stock tb wouldnt do any justice for power though
Old Sep 7, 2015 | 11:40 PM
NotARaCist's Avatar
<p>Not a single thing you've shat out on these forums gives us any reason to believe that you need an oversized TB. &nbsp;Get a stock unit, or if you insist on needing aftermarket, get something that isn't ****. &nbsp;Go through the old posts around here, and you'll see a long history of Junk2 TBs being absolute ****.</p>
wade
Mar 18, 2009 01:14 PM
prelude_93vtec
Jun 3, 2007 08:23 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
Slow_h22
Aug 1, 2004 03:25 PM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
