should i worry?
Old Oct 5, 2004 | 06:38 PM
Btothe3rdDegree's Avatar
Default should i worry?
i was out street tuning and i noticed taht between shifts if i paused before putting it into the next gear it goes lean for a sec then goes back to normal, should i worry about it or is it normal?
Old Oct 5, 2004 | 06:39 PM
MooreBoost's Avatar
Default Re: should i worry? (Btothe3rdDegree)
So your throttle is at 0% correct?
Old Oct 5, 2004 | 06:59 PM
Default Re: should i worry? (tegunderpressure)
yep, it dips for a sec and then goes back to normal
Old Oct 5, 2004 | 07:13 PM
Freemantle's Avatar
Sounds stupid, but do you have a lightened clutch? I had that happen on a Del Sol between shifts. The tach would climb about 700~rpms and the PLX would throw out a lean reading. The rest of the map was beautiful so we didn't worry about it. That was early August and he still has no complaints.
Old Oct 5, 2004 | 11:39 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">i was out street tuning and i noticed taht between shifts if i paused before putting it into the next gear it goes lean for a sec then goes back to normal, should i worry about it or is it normal?</TD></TR></TABLE>
I believe the computer puts you in decel mode for that split second you are still in gear with the throttle closed. Most ECU's are programmed to cut off injector duty in decel mode hence the lean reading. Just a guess though.
GranddaddyPurple
Feb 21, 2008 08:54 PM
CXtypeR
26
Feb 19, 2007 03:59 PM
lpwrestler917
Jan 25, 2007 07:08 AM
z51LS2
Apr 16, 2006 05:17 PM
Keewun
Jan 7, 2005 08:22 AM
