Should I remove my cat?!
Old Feb 20, 2006 | 08:33 AM
IntegraMastaz's Avatar
Default Should I remove my cat?!
Hi all here is my setup:
-B18b1
-Turbo T3
-Front mount Intercooler
-injecteur blue top
-Blox manifold
-wastegate deltagate
-Manual boost controler
-pump a gaz walbro 255
-ligne d'Exhaust 3"
-Custom DOwn pipe de 2.5"
-High flow cat 3'' Magnaflow
-Muffler Magnaflow
-resistor Box pour injecteur low impedance
-Gauge Air/Fuel et Boost
-BOV de eagle Talon Tsi
-Ecu P06 chipper Hondata S100
-clutch Bully stage 1
-Ngk R Spark plug
I was wondering If I would gain something by removing the Cat or since its 2.5DP to 3'' Cat and 3'' Cat back It wouldnt do much?!
Old Feb 20, 2006 | 09:49 AM
JDM00SI's Avatar
Default Re: Should I remove my cat?! (IntegraMastaz)
remove cat!
get a 3 in testpipe welded in or something.
Old Feb 20, 2006 | 12:20 PM
INTEGRA_boy's Avatar
Default Re: Should I remove my cat?! (JDM00SI)
ya romove the cat..it will free up quite a bit of horsies..nothing crazy but maybe like 5-7 hp maybe
Old Feb 20, 2006 | 01:09 PM
XX Boosted Si XX's Avatar
Default Re: Should I remove my cat?! (INTEGRA_boy)
i had no cat for a while and honestly I got tired of the smell and smoke. Now i run a 3 inch cat and when I retuned I didnt even notice a loss in power at all with the cat, and adleast 75% of the smell and smoke is gone
Old Feb 20, 2006 | 03:25 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: Should I remove my cat?! (XX Boosted Si XX)
remove the cat, you'll benefit on an earlier spool time even for a T3
Old Feb 20, 2006 | 04:27 PM
turbosnatch's Avatar
its bad for the environment
i run an open dump
Old Feb 20, 2006 | 04:31 PM
SOHCD16y8's Avatar
Default Re: (turbosnatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosnatch &raquo;</TD></TR><TR><TD CLASS="quote">its bad for the environment
Actually many have past emmisions with no cats, such as Adseguy and the car that Dave tuned and there was a post on a while back. They past by quite a bit as a matter of fact.
Old Feb 20, 2006 | 04:57 PM
AspectIndustries's Avatar
Default Re: (SOHCD16y8)
Run no cat Get it tune properly though
prelude_93vtec
Jun 17, 2007 02:08 PM
JDM00SI
Oct 15, 2005 09:14 PM
