pls help car won't start help asap
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
Wasup guys
Well I having problem starting my car cuz I dindnt drive my car for a week only in garage and I took off the ecu and that's it and now one week later put the ecu on and start it won't start so I check the spark plug and I saw a fuel around the plug so iwas like may be the plug so I bought another new set of plug and still didn't start
I don't know what to do
And I forgot to tell u guys I took off the spark plug wire in the distributor and I forgot to mark which one is #1234
Pls help
Thanks guys
Pls help
Thanks guys
B A N N E D
Re: pls help car won't start help asap (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">make sure they are in the right order. maybe this will help.
So this wire should be like that what if the middle one right and the one connected in the middle is pointing upwhat s gonna be my #1234 lmk thanks
Re: pls help car won't start help asap (spoon95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">So this wire should be like that what if the middle one right and the one connected in the middle is pointing upwhat s gonna be my #1234 lmk thanks </TD></TR></TABLE>
im not exactly sure what your asking there.
B A N N E D
Hahha sorry the two circle w/o number so my question is my #1234 if the right circle w/o number is on top
Btw when I open my distributor cap I saw some red powderish all over what is that?
i bet you anything that sparkplug wire order is what is holding you back...
i made the same mistake, except the car started, causing the car to run like ****.
I thought my motor was blown for a while....untill my buddy noticed it.
Re: pls help car won't start help asap (wade)
it also did it to me the other day on a SOHC, i set up the wires like a DOHC config so later find out that SOHC and DOHC are diff!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">it also did it to me the other day on a SOHC, i set up the wires like a DOHC config so later find out that SOHC and DOHC are diff! </TD></TR></TABLE>
opps i think the diagram i posted was for a d-series. ill confirm when i get back from class today.
glad i could refresh your mem
ok heres the damn cliff notes STRAIGHT TO THE POINT FOR YOU
***here is the cylinder head ordering ( 4 3 2 1 )
****the distributor goes like this...
3 4
1 2
3 4
1 2
B A N N E D
Oh **** that's hahahhha somebody confirm this I know a lot of people running b series come guys
thanks wade for confirming, i was pretty sure i used that diagram before and it worked.
btw thanks to 93turbo16 cause i stole that diagram from his website
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">Btw when I open my distributor cap I saw some red powderish all over what is that?</TD></TR></TABLE>
That's called "Red Death" and means the bushing in the distributor sub-assembly is about to take a **** on you. When this wears out, it allows the shaft to wobble which sends out 'incorrect' ignition waveforms to the ECU. You can try searching for a replacement bushing/bearing but I don't know that anyone ever found one to work. Honda certainly doesn't make one - you can only get the sub-assembly from them.
B A N N E D
Re: pls help car won't start help asap (EE_Chris)
Oh no so that mean I should change the whole thing or where can I buy those bearing honda dealer? Lmk thanks for all the inputs <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">That's called "Red Death" and means the bushing in the distributor sub-assembly is about to take a **** on you. When this wears out, it allows the shaft to wobble which sends out 'incorrect' ignition waveforms to the ECU. You can try searching for a replacement bushing/bearing but I don't know that anyone ever found one to work. Honda certainly doesn't make one - you can only get the sub-assembly from them.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">That's called "Red Death" and means the bushing in the distributor sub-assembly is about to take a **** on you.</TD></TR></TABLE>
that blows. chris always has good info especially when it comes to electrical components. how you doin btw havent really seen you around in a while.
Like I said, I know of no one that has sourced a replacement bushing/bearing, so at this point your only option is to get it from the dealer/online. So you don't need to buy a whole distributor, just the sub-assembly - the cage, if you will. You can transplant all your other stuff over to it (coil, igniter, etc).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">how you doin btw havent really seen you around in a while.</TD></TR></TABLE>
Hanging in there - work is kicking my ***. I see you're turbo now (I thought I did in another post) - good deal. Still rockin' that P28 with a ghost in it?
Hanging in there - work is kicking my ***. I see you're turbo now (I thought I did in another post) - good deal. Still rockin' that P28 with a ghost in it?</TD></TR></TABLE>
yeah work is a pita. but yeah im turbo now. remember it was a p72 with the phantom code. i switched to a converted p06 and uberdata. disabled the o2 heater that way so no more code.
gsrpedro
12-05-2008 11:42 AM
fwdftw
52
09-05-2006 11:31 PM
