SHould i get MSD?
i have d16z6 with zex cam, y8 intake manifold,ls throttle body and some basic bolt ons. I'm going to get zex nitrous but should i get the MSD and if so which one should i get.
I have a 6AL. It has been good to me so far. I would recommend it to anyone using FI or N2O. You can get more expensive ones with rev. limiters and things like that but I didn't need it because I have other electronics that take care of that. If you are running stock bottom end the factory rev. limiter is fine for you anyway. Just don't run nitrous all the way to the limiter. Bad things happen. I have never done it but lots of people have only to end up with broken motors
But Ben is right, unless you are going to do more later the Honda ignition is nothing to sneeze at.
[Modified by fastestdriver, 4:24 PM 2/3/2002]
But Ben is right, unless you are going to do more later the Honda ignition is nothing to sneeze at.[Modified by fastestdriver, 4:24 PM 2/3/2002]
shhh151
May 26, 2006 08:20 PM
