should i drop my comp?????
Old Mar 11, 2003 | 05:11 AM
mackbull's Avatar
Default should i drop my comp?????
ok im boosting my GSR ek for bit them this white smoke came out my breather fine blowby i found out ring gone ok no problem i was ready for something like this to happen now im facing a delema what to do drop the compresion or stay with the stock one i what to bliuld up the bottom end should i drop it to 9:1 or just get stock but higher end piston rod are going to be new and also undecisive on a crank to stay stock pick up a new one there nothing wrong with the stock one but dont know what to do with that and should i also do the head up bit with retainers and cams i have itr cam in there now but had those before the turbo should i pop for new set of cam or the itr fine
Old Mar 11, 2003 | 01:25 PM
mackbull's Avatar
Default Re: should i drop my comp????? (mackbull)
Old Mar 12, 2003 | 04:05 PM
mackbull's Avatar
^^ again
Old Mar 12, 2003 | 04:55 PM
DefiantGSR's Avatar
low boost: stay at 10:1
high boost(15+psi) : go 9.5:1
go with GSR cams. ITR cams vs GSR cams has been beaten to death.
jksmith
Nov 3, 2008 05:52 PM
JsNA99si
Mar 12, 2004 10:08 PM
Charlie Moua
Mar 31, 2003 08:30 AM
madman604
Nov 7, 2002 07:46 PM
B00ST2nR
Jun 29, 2002 11:27 PM
