Should a chipped ECU be reset as normal? 93GS
Old Aug 6, 2007 | 10:39 AM
MantisX's Avatar
Default Should a chipped ECU be reset as normal? 93GS
I have a chipped ECU that I have programmed right now with launch control and the CE as the shiftlight. My question is, does it need to be reset like a stock ECU? I have a 93 and the way I used to reset was remove a fuse under the hood, wait 10-15, put it back and let the car run with all accessories off. Does chipped ECUs require the same treatment?
Thanks
MantisX
Old Aug 6, 2007 | 10:56 AM
mtber's Avatar
Default Re: Should a chipped ECU be reset as normal? 93GS (MantisX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MantisX &raquo;</TD></TR><TR><TD CLASS="quote">I have a chipped ECU that I have programmed right now with launch control and the CE as the shiftlight. My question is, does it need to be reset like a stock ECU? I have a 93 and the way I used to reset was remove a fuse under the hood, wait 10-15, put it back and let the car run with all accessories off. Does chipped ECUs require the same treatment?
Thanks
MantisX</TD></TR></TABLE>
Yes, you can re-set the ecu the same way.
Shat is making you think you need to re-set the ecu ? Just curious.
Old Aug 7, 2007 | 05:43 AM
MantisX's Avatar
Default Re: Should a chipped ECU be reset as normal? 93GS (mtber)
Well the reason I asked is because Its a stock map loaded right now only with the added shiftlight and launch control. I figured since the map was stock, the car would still need to learn again.
Thanks
MantisX
i20ar
Jul 19, 2004 07:42 AM
strict 9 ef
64
Feb 14, 2004 12:45 PM
s2000june
16
Feb 4, 2004 07:07 PM
volkracing99
Jan 17, 2002 01:06 PM
