SFP manifold....
Old Jan 16, 2004 | 04:56 AM
GDM Z28's Avatar
Default SFP manifold....
i just put a SFP manifold on my boosted LS. but the way the runners are set up i cant get the dip stick in the hole cause one of the studs from the head is blocking it....has any one else had this problem? for a temp. fix i bent the dipstick tube to the drivers side alittle so i can get it thourgh the next runner, but i was told this will throw the dip stick off alittle. can any one help me out here?!? and also if you have a sfp mani, how did u tighten the middle bolt? i cant tighten that at all!
Old Jan 16, 2004 | 06:02 AM
Mad Cow's Avatar
Default Re: SFP manifold.... (civicflnum1)
Bending the handle of the dipstick won't "throw" anything off. How can that affect anything?
Old Jan 16, 2004 | 10:02 AM
GDM Z28's Avatar
Default Re: SFP manifold.... (MadCow)
i dont know thats why i asked
Old Jan 16, 2004 | 11:35 AM
anothaRRR's Avatar
I tightened the bolt up by hand as much as I could and then managed to fit a 12mm wrench. My dipstick still fits in there, Once you tighten that bolt you might be able to fit the dipstick in there. Just tighten it as much as you can by hand and then youll be able to fit a wrench, at least I was able to. Good luck.
Old Jan 16, 2004 | 02:10 PM
GDM Z28's Avatar
Default Re: SFP manifold.... (anothaRRR)
did you tighten it from the bottom behind the turbo? cause i cant get a wrench on there from the top and its hard as hell to get it form the back
Old Jan 16, 2004 | 02:53 PM
anothaRRR's Avatar
I was able to tighten it from the top, without the dipstick on there. Like I said, tighten it all you can by hand then try to stick the wrench in there, it might be that my wrench is thinner or something.
Old Jan 16, 2004 | 04:33 PM
AlphaKennyWun's Avatar
I fixed it by taking the stud out from the head and replacing it with a bolt.
Old Jan 16, 2004 | 07:35 PM
anothaRRR's Avatar
Default Re: SFP manifold.... (S03Burner)
uhm, my head only has 2 studs one on each end, the rest are bolts, thats probably why I managed to do it.
Old Jan 16, 2004 | 07:38 PM
aka010010
Guest
Posts: n/a
hey how much did your sfp manifold cost you? a friend of mines is gunna buy one soon.
Old Jan 17, 2004 | 06:13 AM
GDM Z28's Avatar
Default Re: (aka010010)
mine was 350 with a 2.5" DP. but the mani was glass beaded and re painted black by sfp. i love them!
Old Jan 17, 2004 | 06:55 AM
g5r's Avatar
g5r
Default Re: (civicflnum1)
where did you buy one from? im looking for a sfp mani. also.
Old Jan 17, 2004 | 07:32 AM
Default Re: (g5r)
ww.sfp.net
Ive had mine on for almost two years w/no problems. Its a good manifold.
Old Jan 17, 2004 | 11:58 AM
GDM Z28's Avatar
Default Re: (g5r)
i know a guy that sells them, let me tell him ur looking for one and ill get back to you. what motor n turbo n WG do u need one for?
Old Jan 21, 2004 | 12:12 PM
g5r's Avatar
g5r
yea i been looking for one, i need a t3 flange and im using a 38mm wastegate.
Eppo
Jul 11, 2011 08:37 PM
Momentum
14
Mar 4, 2010 06:40 PM
nojoke
Feb 12, 2005 05:23 PM
tyflip2
Jun 16, 2004 12:19 PM
crx1856
Aug 11, 2003 05:07 PM
