Setup Critique
Old Jul 7, 2005 | 09:56 PM
LSEGHATCH's Avatar
Default Setup Critique
Ok first let me ask if this is a non-flamable issue, if not I will post up my in progress setup and would like some critiqueing.
Old Jul 8, 2005 | 07:55 AM
LSEGHATCH's Avatar
Default Re: Setup Critique (LSEGHATCH)
Old Jul 8, 2005 | 08:52 AM
jdm'dc2sc61's Avatar
im curious about your setup, shoooooooooooooooow me
Old Jul 8, 2005 | 08:53 AM
Dunc's Avatar
BCICAN
I am assuming you are posting what you currently have in your car and then you want us to say "yay" or "nah" to the parts and give alternatives to the "nah's" correct?
If that's the case, post it up.
I am sure someone will flame away, but it's Honda-Tech and you have to sift through 10 posts of drama to get to 1 good post haha.
Old Jul 8, 2005 | 08:55 AM
LSEGHATCH's Avatar
Default Re: Setup Critique (Dunc)
This is going into my current build and would like to trim it up if I could ahead of time, instead of buying something and finding another product that would better suite my needs.
Old Jul 8, 2005 | 08:56 AM
Dunc's Avatar
BCICAN
oh, then definitely post up man...we'll try and help.
Old Jul 8, 2005 | 09:25 AM
boostedcivicsir's Avatar
Mr. Badwrench
although we cant guarantee no flaming if there is XS Power parts.
Old Jul 8, 2005 | 09:42 AM
Dunc's Avatar
BCICAN
Default Re: Setup Critique (boostedcivicsir)
but instead of flaming because of those parts, we could just say switch it out for something else
Old Jul 8, 2005 | 10:14 AM
Mr. Badwrench
i was speaking for the masses. not me. if you go down that road you will just learn the hard way.
Old Jul 8, 2005 | 10:34 AM
LSEGHATCH's Avatar
Ok let's see if I can name everything......
SC-61 T4
One-Fab Top Mount Exhaust Mani
3" downpipe/3" exhaust
44mm Tial Wastegate
Precision 750 Intercooler
???? BOV(s)
Fluidyne/PWR 1/2 sz. Radiator
70mm Throttle Body
Sheet Metal Intake (GE, STR, etc..)
1000cc Peak Hold RC's
B18A 81.5 bore (build by Exospeed)
B16 Head (p&p, 3/5 angle valve job, larger flat top valves, dual Ti springs/retainers, and gsr cams)
AEM Tru Times
Hondata Stage 4 (old school )
............there might be more but I'm drawing a blank
Old Jul 8, 2005 | 10:39 AM
Mr. Badwrench
thats a hell of a lineup you got goin. should put down some good numbers.
Old Jul 8, 2005 | 10:52 AM
LSEGHATCH's Avatar
I hope, its going in a really light eg so that'll help.
Old Jul 8, 2005 | 11:05 AM
Nidius's Avatar
Compression?
Old Jul 8, 2005 | 11:09 AM
LSEGHATCH's Avatar
Default Re: Setup Critique (NidStyles)
9:1
Dunc's Avatar
BCICAN
mmm lovely sounding
Also, you may want to look into Precision 1000's instead of the RC's (just food for thought)
I agree with NidStyles: what is the compression. You forgot to mention anything about the block.
BOV: A Tial 50mm would give you plenty of exhaling* abilities... although the BOV is really a personal opinion. As for me I am going to run the HKS, and if I need another one then I'll buy it haha. "Two's better than one" right? haha
Old Jul 8, 2005 | 11:20 AM
LSEGHATCH's Avatar
Block:
Darton Sleeves
Arias Pistons 81.5mm
Compression 9:1
Eagle Rods with ARP bolts
Honda OEM Bearings: rod and mains
Honda OEM Bottom end gasket kit; Oil pan gasket, oil pickup gasket, main seals.
Honda OEM Oil pump
Z10 Main Gridle
Micropolished Crank
Moroso or similar Oil Pan
GSR oil Pump
Type R Water Pump
Yeah I was thinking about the HKS SSQV or 2 Greddy Type RS
Old Jul 8, 2005 | 11:29 AM
BoostedEG6's Avatar
your setup sounds pretty nice but I would stay away from the Z10 block girdle or get it machined when its installed cause it will throw things off in the bottom end if not installed properly. I have seen it happien first hand
Old Jul 8, 2005 | 11:34 AM
LSEGHATCH's Avatar
Default Re: Setup Critique (BoostedEG6)
Well like I said the guys from Exospeed are building the block so I have no doubts in their ability to do good work, they also stood behind my decision for the gridle.
Old Jul 8, 2005 | 01:06 PM
Dunc's Avatar
BCICAN
to be honest, I really don't see anything wrong with your setup...and I wouldn't change anything either. I want a dyno chart now
Old Jul 8, 2005 | 08:07 PM
LSEGHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">to be honest, I really don't see anything wrong with your setup...and I wouldn't change anything either. I want a dyno chart now </TD></TR></TABLE>
In Time...
Old Jul 26, 2005 | 07:36 PM
LSEGHATCH's Avatar
So is my T4 SC61 going to be lagging to where I should look at something else? I'm a little worried about lag due to some posts I've been reading.
Old Jul 26, 2005 | 07:41 PM
b16sedan's Avatar
I'd be more worried about ever getting your exospeed motor back.
Old Jul 26, 2005 | 07:55 PM
LSEGHATCH's Avatar
Default Re: Setup Critique (b16sedan)
Ooops forgot to say
EDIT: BENSON IS GOING TO BE DOING MY BUILD
I got lucky by waiting
rokwilder1
Aug 5, 2009 02:28 PM
turbohatch eg6
Jul 2, 2009 06:40 PM
boosted350z
Dec 2, 2004 06:19 PM
joey1320
Jul 25, 2003 11:35 AM
