Serious valve tap issues, need help!
Old Apr 28, 2003 | 05:12 PM
Rah Rah's Avatar
Default Serious valve tap issues, need help!
While my car was being dyno tuned it developed a serious valve tap. I figured, no sweat, probably loosened them from over-reving on the dyno. I go to adjust them and everything was going fine until one of the intake valves of piston 2. I loosened the bolt and tightened the lash to the limit. The gap was about a little less than an eighth of an inch!!! The gap would not close at all. This is with it screwed to the max!! I was like WTF? I then wiggle the piece underneath the bolt/screw (sorry don't know the terminology--my helms is in the car) and it's loose as hell compared to the opposing valve. Can anyone give me some insight/advice/estimate/idea of how serious/etc., etc....
Old Apr 28, 2003 | 05:16 PM
niedejb's Avatar
Default Re: Serious valve tap issues, need help! (sando112)
If the valve is bent it wont properly seat and will be shorter than normal making the gap bigger than normal.
Hows the compression on that cylinder.
Old Apr 28, 2003 | 05:23 PM
Rah Rah's Avatar
Default Re: Serious valve tap issues, need help! (niedejb)
I haven't checked it
Old Apr 29, 2003 | 01:15 PM
1.8T_EG's Avatar
how do you know if your valves are tapping?... what does it sound like?...
Old Apr 30, 2003 | 06:09 PM
Rah Rah's Avatar
Default Re: Serious valve tap issues, need help! (1.8T_EG)
sewing machine sound
raverx3m
May 18, 2011 11:24 PM
SpoolnByYou
Mar 16, 2006 12:49 PM
GSRVTEC1
Oct 31, 2005 01:19 PM
HavokB18
18
Jan 7, 2003 08:50 PM
