serious blow by
Old Oct 3, 2010 | 02:49 PM
bLu92bUbbLe's Avatar
Default serious blow by
i have serious blow by coming out the lil breather cone on the VC...when i take the oil cap off with her running i can blow a quarter at least 6 feet in the air from the blow by...its blowing oil all over the engine bay...my question is what causes this...i was getting the car turbo street tuned when it started...
Old Oct 3, 2010 | 03:19 PM
schock3's Avatar
Default Re: serious blow by
rings
Old Oct 3, 2010 | 03:29 PM
Turbo-LS's Avatar
Sounds like a stock engine with to much ignition timing cracked the piston ringslands and poof excessive blow by
Old Oct 6, 2010 | 11:39 PM
yea its a stock gsr...damn too much timing....so maybe get another tuner....cuz it happened when i was getting the car street tuned.
Old Oct 7, 2010 | 12:01 AM
Hybrid96EK's Avatar
Ummm, sure.. after you get a mechanic to put new pistons and rings in it.
Old Oct 7, 2010 | 12:22 AM
95skunkedgsr's Avatar
new tuner is in needed becuase he shoulda been watchin for that while street tuning, and pistons and rings
Old Oct 7, 2010 | 02:28 AM
cleansi's Avatar
did you have any breather/ventilation to begin with ?
Old Oct 7, 2010 | 03:35 AM
per4mance's Avatar
You are going to need a rebuild or a new motor. Your not going to get out easy on this one. If its blowing that much oil out then the problem is serious.
Old Oct 7, 2010 | 03:29 PM
i build my own motors...i already have the rings and bearings...and im looking for a set of pistons just in case the ringlands are cracked. ok so new tuner it is then.
no i didnt know i needed one for a stock motor.
Old Oct 7, 2010 | 03:58 PM
per4mance's Avatar
Since you build your own motors, you should know that no matter if its built or not a boosted motor needs a breather.
Old Oct 7, 2010 | 04:05 PM
well i had the stock pcv **** on it....i didnt kno i needed the aftermarket catch can....i have to read up on that and familiarize myself with it...any suggestions on the crank vent??
Old Oct 7, 2010 | 06:54 PM
endyne kit aint bad for the buck ... tank might fill up fast on you tho
Old Oct 7, 2010 | 07:17 PM
what happens when it fills up....
Old Oct 7, 2010 | 08:47 PM
B and B's Avatar
Loved
Community Favorite
It'll overflow and be restricted for further venting...like a little kid blowing through his straw into his drink..lol
and I have two buddies with 400+ b series and both are using the stock black box...I don't see how they do it..no blown gaskets or anything.
I blew about about an inch of oil pan gasket out when I had my block vent hoses kinda pinched into a Monster can my bore/hone came out a little loose tho, see sig.
EKB18BPR3
Jul 4, 2007 04:54 PM
Stock@$$GSR
Feb 19, 2006 05:37 PM
bboyoxygen
11
Nov 2, 2004 09:55 PM
ActiveAero
Jan 2, 2004 11:51 AM
tominos
22
Feb 18, 2003 08:55 PM
