Seal on fuel return line...
Old Aug 6, 2002 | 09:20 PM
PrecisionH23a's Avatar
Default Seal on fuel return line...
Well i finally got my fuel tank lid fabricated to where i can run the lines properly, now that i have it in the damn viton o-ring on the top part tore in half... I was going to run a strat-o-seal on top but there was NO room for it, so i figured viton would do the trick. There is a stratoseal underneath however. Anyways here is how it turned out:
Then once i connected the 6an hose to it the ring tore...
I have a feeling i have to take everything apart again and install that o-ring since i tightened the bolt down too much, correct? How exactly does pressure affect the return line at all? Im just curious, i dont want to leak gas or have any fumes in my car so i know i gotta replace it, its just gonna be a pain in the ***. Plus, i had to retap the stock thread on the feed to a 12mmx1.5 and the fitting didnt screw all the way down so JUST to be safe i put jbweld around the fitting so it has no leaks at all. I really am kind of iffy about this set up, this is the only thing i have jigga rigged and i just wanted some feed back from you guys. Do you think its ok? Should i replace the o-ring?
Old Aug 7, 2002 | 05:18 AM
boomslang's Avatar
Default Re: Seal on fuel return line... (GudeH23a)
There is basically no pressure in the return line. But you will want it air tight for sure.
Old Aug 7, 2002 | 05:28 AM
Farnsrocket's Avatar
Default Re: Seal on fuel return line... (Inlinefour)
go to the hardware store and look for a washer that will just fit over the o-ring......I know it's tight, but that elbow isn't going to hold the o-ring well. BTW, Napa sells fuel resistant o-rings real cheap
Old Aug 7, 2002 | 10:34 AM
Default Re: Seal on fuel return line... (Farnsrocket)
i have the -6an stratoseal grommet but the problem is i cant get it to fit because the metal round hub that has the threading for the feed line is in the way. If i cant get this sealed properly, i am going to have the threaded nut cut off and have a plate welded over then use different fittings. Basically im looking at a 8an-4an union, 8an straight swivel to connect to the 8an hose, and a 4an straight swivel to connect to the union under the lid of the tank then run the fuel hose from the swivel seal to my fuel pump... i hate to do it over again but id rather be safe then sorry.... But maybe i can get away with just replacing the oring... we'll see. thanks guys.
Old Aug 7, 2002 | 11:13 AM
take a dremel and flatten the one side of the stratoseal that is hitting your feed line. It may melt the o-ring if it gets too hot though.
Old Aug 7, 2002 | 11:17 AM
yea i took the dremel already and notched it out so i could fit the 90deg 6an fitting in there... i just dont wanna dremel it out too much...
B_Swapped93
Apr 4, 2019 10:02 PM
boarding2008
10
Aug 1, 2010 09:01 AM
JLefevers
Jan 1, 2008 09:20 PM
1QwIkEf
Jan 28, 2006 05:05 PM
PrecisionH23a
Jul 30, 2002 07:37 AM
