Scratching my head...help
Old Sep 1, 2009 | 02:22 PM
jsbayer's Avatar
Default Scratching my head...help
I have an AEM UEGO wideband...b18c1, rc310 and hondata s300. When im WOT my a/f numbers actually richen up...going from 13.5-11.5. I have "lean protection" on for fuel cut, so when its hitting the 11.5 it hits fuel cut, and i let out...what the deal? should i be leaning out under boost?
Old Sep 1, 2009 | 03:05 PM
jsbayer's Avatar
Default Re: Scratching my head...help
10 views, no one has any ideas?
Old Sep 1, 2009 | 03:39 PM
spoolin94ls's Avatar
is the car tuned for ur set up or are u usin a base map on the hondata
Old Sep 1, 2009 | 03:55 PM
boostedEF91's Avatar
when WOT it should richin up as it starts to go into boost you need more fuel.. this is a boosted car right.? need more info.
Old Sep 1, 2009 | 03:56 PM
and the higher the number on the gauge the leaner the car. 11.5 would be rich. 13.5 would be more lean.?
Old Sep 1, 2009 | 04:31 PM
crashsvg's Avatar
yes..lower is actually richer.
so 11.5 on a wide bad is quite rich in boost.12.5 being max rich power while 13.5 and up is a big NO for boosted cars for na applications its just perfect...
if the car has already been tuned your tuner put it at that level to allow a bit more cooling in boost.
Old Sep 1, 2009 | 04:48 PM
bigD's Avatar
thats a little on the lean side for me, I tune my cars from 11.5 -11.8 wot for boost depending on psi and setup and 12.8-13.2 na.
Old Sep 1, 2009 | 05:52 PM
jsbayer's Avatar
Sorry for the lack of info, yes it is boosted. And i traded the car for my bike. He built it and had it "tuned" but the car ran like crap, so i took the tune of s300, and have started from scratch. I guess i was bass-ackwards, for some reason, i thought lower the number was lean, and higher the number was rich...my thinking was "air-fuel" so the lower the more air was in the mixture, and the higher the number meant more fuel in the mixture. DOH!
Anyways, im using the s300, and stock fuel pump, and rc310 injectors, so without me touching the fuel maps, i would think the 310s dump more fuel as they sit, and i found it odd that it richens under boost...i would think it would lean out as i am forcing more air in?
Am i just retarded or what do you all think? lol
Old Sep 1, 2009 | 06:41 PM
crashsvg's Avatar
ok those are good numbers when tuning too but the power difference between 11.5 to say 12 is barely 1%...on the other hand the difference of 11 and 12.5 afr is about 3-5%..
and from the sound of his setup with 310cc injectors hes pob just running 5-7psi.... so him running 12.5 afr hell be ok even on stock timing....
just ensure the car is not running anything below 11 afr or that will significantly kill the power of your car
Old Sep 1, 2009 | 07:05 PM
jsbayer's Avatar
Crashsvg, i am on the 310, my boost guage shows 10lbs, s300 boost cut is at 10lbs, and im on a stock map, so 10lbs is it. havent explored timing, keep the car above 11 afr, because below 11 is tooo rich. what else can you guys learn me? lol
Old Sep 4, 2009 | 03:45 AM
crashsvg's Avatar
theres nothing else id advise you to do other than to get the car retune by a good tuner if you wana feel more power..
Judge Owens
Feb 28, 2015 06:00 PM
boostedb18kid
Dec 24, 2007 09:52 AM
underpressure02
Apr 24, 2005 04:16 PM
angela_itr
Apr 11, 2005 09:48 AM
underpressure02
Nov 8, 2002 04:28 PM
