sc6152e too small for built motor??
Old Feb 4, 2006 | 05:47 PM
spec_v_kid's Avatar
Default sc6152e too small for built motor??
I am putting a 400-450whp turbo gsr together, its 81.5 stock sleeve 9:1 gsr w. top mount and all goodies... i was thinking sc6152e (630whp rated) will be preffect for the set up, but from reading on this forums for few months, seens like almost every 400+whp bseries here run PT or GT series turbo. I wonder if i could still run that little sc6152 for now then up grade later. or will this turbo get me to 450whp range??
thanks
Old Feb 4, 2006 | 06:59 PM
Zakar's Avatar
sc61 is a popular hondatech pick..
Old Feb 4, 2006 | 09:50 PM
GiNuWiNe's Avatar
Default Re: (Zakar)
That turbo should suffice for 450whp.
Old Feb 4, 2006 | 09:53 PM
Ti3d in's Avatar
Default Re: (GiNuWiNe)
A lot of people on HT run much too big turbos on street cars.
Old Feb 5, 2006 | 06:48 PM
spec_v_kid's Avatar
Default Re: (Ti3d in)
more info?
Old Feb 5, 2006 | 06:49 PM
SOHCD16y8's Avatar
youll be happy with it. Im running it on my car and the spool is really good, it has a very nice broad powerband and will be plenty for 450whp.
Old Feb 6, 2006 | 02:10 AM
ccfab's Avatar
Default Re: (SOHCD16y8)
im running a gt35r on the street, its damn sick
Old Feb 6, 2006 | 02:23 AM
D@nnY's Avatar
Default Re: (ccfab)
sc61523 on a 81 mm ls vtec made 530 on 21 psi and 110 makes 500s all day
Old Feb 6, 2006 | 08:21 PM
spec_v_kid's Avatar
Default Re: (D@nnY)
kool... THANKS... still want more inputs
Old Feb 6, 2006 | 08:26 PM
boosted-EG6's Avatar
Default Re: sc6152e too small for built motor?? (spec_v_kid)
a buddy of mine dyno'ed 450 on 9 pounds with a drag mani and a sc61 turbo should you should have know problem
Old Feb 6, 2006 | 08:35 PM
boosted92's Avatar
Default Re: sc6152e too small for built motor?? (boosted-EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted-EG6 &raquo;</TD></TR><TR><TD CLASS="quote">a buddy of mine dyno'ed 450 on 9 pounds with a drag mani and a sc61 turbo should you should have know problem</TD></TR></TABLE>
Not without a massive correction factor he didn't. Most I've ever seen ACTUAL out of a 9psi SC61 was a car tony1 tuned a good 2.5 years ago with (IIRC) an 84mm 10:1 GSR motor, full-race tubular manifold, and all that good stuff. It made 372 @ 9 psi. 450 actual WHP on a drag mani at 9 psi just isn't happening.
Old Feb 7, 2006 | 04:23 AM
D@nnY's Avatar
no..he didnt
Old Feb 7, 2006 | 04:28 AM
m R g S r's Avatar
go w/ the new ball bearing center cart.....
Old Feb 7, 2006 | 09:57 AM
swapit's Avatar
Default Re: sc6152e too small for built motor?? (m R g S r)
im using that same turbo and made 600hp 420ft lbs at 28.5psi.im on a b16a at 84.5mm bore stock stroke.
Old Feb 7, 2006 | 10:08 AM
rudebwoy's Avatar
sweet! sounds good, I am running the same turbo plans 11 psi low boost and 20 high boost on the dsbc
Old Feb 7, 2006 | 10:11 AM
nsxmatt's Avatar
With the drag manifold i'm sure it spiked to 20lbs.
Old Feb 7, 2006 | 01:19 PM
Importordomestic's Avatar
Default Re: sc6152e too small for built motor?? (nsxmatt)
what kind of spool times are you guy's seeing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapit &raquo;</TD></TR><TR><TD CLASS="quote">im using that same turbo and made 600hp 420ft lbs at 28.5psi.im on a b16a at 84.5mm bore stock stroke.</TD></TR></TABLE>
^^ especially you, my setup is the same bore.
Old Feb 7, 2006 | 02:12 PM
The Weather Man's Avatar
Hm...............
Thats a good question about spool times. I'm going with this turbo in my setup for the Prelude.....can't wait. Someone told me boosting 12psi - I won't get full spool until ~4500 which is fine for me.
Old Feb 7, 2006 | 04:41 PM
ccfab's Avatar
Default Re: (TheKINGPin)
go gt series. if your gonna spend 800 spend the 1200 and get the dual ball bearing
this gt35r makes my heart stop and gives me blood clots in my lungs when it spools
Old Feb 7, 2006 | 05:35 PM
93hatched_projekt's Avatar
Default Re: (ccfab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab &raquo;</TD></TR><TR><TD CLASS="quote">go gt series. if your gonna spend 800 spend the 1200 and get the dual ball bearing
this gt35r makes my heart stop and gives me blood clots in my lungs when it spools</TD></TR></TABLE>
I give the sc61 a big thumbs up . It only runs about $600 compared to $1100-1200. You'll be able to make 450 Whp all day with a nice powerband .
Old Feb 7, 2006 | 07:49 PM
spec_v_kid's Avatar
Default Re: (ccfab)
i wish i could go back, at first i was planning to do a cheap stock motor + turbo and hit 350whp and call it a day.... End up, semi-built the motor and went w. a crazy topmount set up. so it was too late to go back.//
Old Feb 7, 2006 | 10:25 PM
ccfab's Avatar
Default Re: (93hatched_projekt)
for comparisons sake, my buddy jordan has a sc6152e on his built b18c in his teg gsr and i have a gt35r on my built b16a in my gsr.
i see boost before he does, and the gt35r pulls much harder when it spools.
despite the displacement disadvantage, the bigger turbo spooled faster on the smaller motor. thats worth an extra few hundred to me
Old Feb 7, 2006 | 11:36 PM
RogueWorks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">I give the sc61 a big thumbs up . It only runs about $600 compared to $1100-1200. You'll be able to make 450 Whp all day with a nice powerband .</TD></TR></TABLE>
Unless you buy a used SC61 or someone whoring out old stock, you won't find one for $600
Old Feb 7, 2006 | 11:57 PM
ccfab's Avatar
Default Re: (RogueWorks)
i thought the latest price tag for a new sc6152e was around 780 i believe.
Old Feb 8, 2006 | 05:32 AM
SOHCD16y8's Avatar
Yeah the prices went up about 6 months ago, I think the were like 660 and went to 780 althought ive been seening them in the 860 range some places lately.
