SC61 vs SC60
Old Apr 26, 2004 | 11:45 AM
M.A.R.C.'s Avatar
Default SC61 vs GT35E vs SC60
OK I've posted a lil on this before but things have changed a lil since then. Right now I have a Precision SC60 (60-1 hifi compressor, .63 a/r turbine w/ stage 3 wheel). it's going on my d16...
77mm bore (~1.7L), ~9.5:1 compression (9:1 je's in z6 block with a y8 head) p&p head with crower springs and retainers, and a zex street n strip cam.
The orignial plan was to keep the head stock. I was considering the SC61 before but because it's only available with a Stage 5 turbine wheel I decided to take the step below and go with the SC60. Now that the head is built I'm considering the change again. Just so you know, I'm aiming for #'s as well as times. I wanna try to make over 400whp. I want to be somewhere in the 12's full interior or faster but 12's will do for now. I'm also considering the GT35E. What do you guys think? Turbodcx I know has used the Cheapturbo.com version of the SC61 and it made good power on his setup.
UPDATE... I grew some ***** and got the SC61
Modified by CivicRyda2k at 4:34 PM 5/17/2004
Old Apr 26, 2004 | 11:51 AM
8200RPM's Avatar
local hippie
Default Re: SC61 vs GT35E vs SC60 (CivicRyda2k)
Can I drive it?
lewd43's Avatar
i think you'll need Fat Man Scoop here to help with ru traction issuses
and as far as i think about sc60 or sc61. I'll use someone else's quote
"GO BIG OR GO HOME!!!"
Old Apr 26, 2004 | 11:54 AM
8200RPM's Avatar
local hippie
Default Re: (lewd43)
Yea thats something you'll need to work with once you get the car running... traction.
Im sure your setup will do fine- your car is/was running nice and strong. Once the head is done it should feel even smoother.
And you might want to get a new tranny, no?
So... like I said, let me drive it and Ill run 12's
Old Apr 26, 2004 | 11:59 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">OK I've posted a lil on this before but things have changed a lil since then. Right now I have a Precision SC60 (60-1 hifi compressor, .63 a/r turbine w/ stage 3 wheel). it's going on my d16...
The orignial plan was to keep the head stock. I was considering the SC61 before but because it's only available with a Stage 5 turbine wheel I decided to take the step below and go with the SC60. Now that the head is built I'm considering the change again. Just so you know, I'm aiming for #'s as well as times. I wanna try to make over 400whp. I want to be somewhere in the 12's full interior or faster but 12's will do for now. I'm also considering the GT35E. What do you guys think? Turbodcx I know has used the Cheapturbo.com version of the SC61 and it made good power on his setup.</TD></TR></TABLE>
You knwo what my answer is.
Old Apr 26, 2004 | 12:05 PM
*Boostwerks*'s Avatar
Keep the SC60.
The SC61 bandwagon is great...but not for everyone.
That turbo you have can do 500whp easy.
Old Apr 26, 2004 | 12:27 PM
M.A.R.C.'s Avatar
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
You knwo what my answer is. </TD></TR></TABLE>
lol stunnah!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Keep the SC60.
That turbo you have can do 500whp easy. </TD></TR></TABLE>
yah i understand that... that's why i'm checking out my options. another factor a friend of mine reminded me of was spool time and the limitations of the turbine wheel. Like I mentioned... the sc60 has a stage 3 wheel, the sc61 comes in a stage 5 wheel and i'm under the impression that the GT35E has a GT turbine wheel which I don't know too much about. I'm definitely not thinking about total peak power either. I would want a DECENT usable power band... but mainly I'm looking for 1/4 mile times/traps and power goals.
Old Apr 26, 2004 | 12:35 PM
The GT turbine wheel is comparable from what I understand to the stage 5 wheel.
It flows like a T4 wheel, but can fit in the smaller T3 housing.
I've seen 540whp on the Stage3 wheel...so it won't limit you by any means.
Old Apr 26, 2004 | 01:28 PM
TurboJesse
Guest
Posts: n/a
if you don't run 12's wait make that 11's with 400+ whp you don't deserve your car
Old Apr 26, 2004 | 01:32 PM
SpoolnG2's Avatar
Old Apr 26, 2004 | 01:33 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">Turbodcx I know has used the Cheapturbo.com version of the SC61 and it made good power on his setup.</TD></TR></TABLE>
His car did make great power and it dosn't take horridly long to spool. i met him this weekend and he talked a little about the car and it sounded like he was very happy with the turbo I would go with the cheapturbo version my self i have this thing with Persicion
Old Apr 26, 2004 | 01:41 PM
M.A.R.C.'s Avatar
Default Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">if you don't run 12's wait make that 11's with 400+ whp you don't deserve your car </TD></TR></TABLE>
hehehe bish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">The GT turbine wheel is comparable from what I understand to the stage 5 wheel.
ah ok i see. well like i said i have my turbo sitting here... i just want to make use of the motor's capabilities efficiently. I want to make as much power as I can while still maintaining a decent powerband, etc. I was talking to brian (turbodcx) and he had the stage 5 wheel on his old turbo and he seemed to like it. I have to look into it more
Old Apr 26, 2004 | 01:57 PM
alpha's Avatar
Default Re: (CivicRyda2k)
The SC61 can come with a 69 trim or 76 trim turbine wheel and if I remember correctly so can the SC60. Keep the SC60
Old Apr 26, 2004 | 01:58 PM
M.A.R.C.'s Avatar
Default Re: (0x64)
yah but i spoke to rod recently and they said they only offer the sc61 now with the 76 trim wheel
Old Apr 26, 2004 | 02:07 PM
alpha's Avatar
So much can change over time I guess I should of said "The SC61 use to come with a 69 trim or 76 trim turbine wheel"
Old Apr 26, 2004 | 06:28 PM
M.A.R.C.'s Avatar
Default Re: (0x64)
yah... the bandwagon is still passing thru... just making sure i don't jump on it because i feel left out . i wanna make sure i have a good turbo for the setup.
Old Apr 27, 2004 | 06:32 AM
M.A.R.C.'s Avatar
so most recommend to stay SC60 then i take it?
Old Apr 27, 2004 | 07:55 AM
M.A.R.C.'s Avatar
bump for soem more questions:
I was now looking at the GT30R... it's a lil more $$$ but from what I've been told the bb helps build a lot more mid range power. it's rated @ 500hp on precision's site and the sc60 i have is rated @ 580 though. any one got insight?
Old Apr 27, 2004 | 08:13 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">bump for soem more questions:
I was now looking at the GT30R... it's a lil more $$$ but from what I've been told the bb helps build a lot more mid range power. it's rated @ 500hp on precision's site and the sc60 i have is rated @ 580 though. any one got insight?</TD></TR></TABLE>
BB is very nice and I almost went with it, but the headache of the water cooling I didn't want to mess with.
Old Apr 27, 2004 | 12:14 PM
M.A.R.C.'s Avatar
Default Re: (ladysman)
eh i guess what i have will be fine
Old Apr 28, 2004 | 09:52 AM
djdxm's Avatar
quit closet racing! both the SC60 and the SC61 are gonna take some work to reach there full potential. Use what you got, decide if you wanna keep it after you break 400whp .... now go put it together and come race me!
-jay
Old Apr 28, 2004 | 09:53 AM
M.A.R.C.'s Avatar
Default Re: (djdxm)
i'm trying to plan it so i dont' have to tear anything off again... been so long once it comes together... it's STAYING together lol
Old Apr 28, 2004 | 09:55 AM
djdxm's Avatar
haha... true! I feel the same way, been so long since mine was together, i dont even know if i can find all the parts!
-jay
Old Apr 28, 2004 | 09:57 AM
M.A.R.C.'s Avatar
Default Re: (djdxm)
yah lol same here. i was looing around my garage and realized i can't find my distributor... my intake manifold is sitting next to my bed. stuff's all over the place
Old Apr 28, 2004 | 11:05 AM
DD_JonnyLee's Avatar
id say the hell with it , sc61, no need to upgrade later
