safe oil pressure?
Old Jun 7, 2005 | 10:36 AM
coupon's Avatar
Default safe oil pressure?
built/boosted h22
idle is at 20psi at 950rpm's
it used to be a lil higher, around 25psi, should i be worried its dropping?
Old Jun 7, 2005 | 10:38 AM
b18bturbo's Avatar
Default Re: safe oil pressure? (nlc)
as long as itis consistent and it is providing oil pressure to your head and block you should be okay.
Some times especailly our texas heat the oil like to thin up alot causing this
Old Jun 7, 2005 | 10:41 AM
coupon's Avatar
Default Re: safe oil pressure? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">as long as itis consistent and it is providing oil pressure to your head and block you should be okay.
Some times especailly our texas heat the oil like to thin up alot causing this </TD></TR></TABLE>
cool, thanks man
Old Jun 7, 2005 | 11:54 AM
mike1114's Avatar
If it used to be one pressure most of the time (average) and now it isn't this is a good indication your bearings might be going.
My pressure was very low in my last motor once I got a oil guage, it was barely 10psi at idle, barely 50psi @3000rpms. These are the Helms limits, if its near them, that may mean a bearing is going.
My #4 rod bearing was fucked bad when we pulled the motor apart. I'm glad I did before the whole thing siezed on me.
trulyshavedintegra
Dec 9, 2012 05:06 AM
Renegade
Feb 21, 2008 09:07 AM
Preludepradit
Oct 12, 2007 01:57 PM
braypunt
Apr 9, 2005 12:04 AM
dominate9
Feb 21, 2005 06:26 AM
